If the signal is very noisy, the low vertical resolution of a scope might not be the best tool for the job (especially if you want to avoid the signal from messing up your frequency response by over driving the inputs). Something like a high-resolution Picotech scope or the already proposed audio interface might give you better results. Or possibly an external analog filter.
