Author Topic: Possible GW Instek GDS-1000B hack  (Read 85564 times)
Offline Herbertl
  • Country: at
Re: Possible GW Instek GDS-1000B hack
« Reply #125 on: May 05, 2019, 09:28:52 pm »
Is there a chance to configure the GwInstek? Like you can do with other scope?
Would like to configure it individually.
The offers in the store have features I do not need and are missing features I do want.
Offline ttyridal
  • Country: no
« Reply #126 on: May 06, 2019, 04:22:34 pm »
It was reported one month or so ago, but I don't know what was the outcome
"don't know what was the outcome" <- that was the reason why I didn't pay attention
I can confirm that firmware 1.23 does not like the latest codes.
Downgrading to 1.12, apply desired licenses and upgrading works fine.
Offline nctnico
« Reply #127 on: May 06, 2019, 05:09:09 pm »
Hmmm... that proves that GW Instek is monitoring EEVblog  ;D
Offline tv84
  • Country: pt
« Reply #128 on: May 07, 2019, 06:52:16 pm »
The new codes were released after 1.23 release date...
Edit: But it seems I overlooked another code combination...
« Last Edit: May 07, 2019, 08:15:49 pm by tv84 »
Offline nctnico
« Reply #129 on: May 07, 2019, 07:02:44 pm »
Well then it seems people are doing things wrong. I was assuming 1.23 was a new firmware version but appearantly it is not.
Offline ttyridal
  • Country: no
« Reply #130 on: May 07, 2019, 07:32:18 pm »
It's possible I overlooked something of course.
I just replaced the four numbers in lis.txt (reply #3) with the ones given in reply #47
Reasonably sure I had the serial number correct both times (no homoglyphs in it)
Offline TK
« Reply #131 on: May 07, 2019, 08:04:38 pm »
It did not work on my GDS-1054B with firmware 1.23
I had to downgrade it to 1.12, apply the hack and upgrade to 1.23
And upgrade does not work when executed from the utility menu, it only works when using SAFE MODE.
But fortunately using SAFE MODE you can downgrade and upgrade from any version to any other version.
I also tested SSH on 1.12 to remove the options file and it works OK.
Offline tv84
  • Country: pt
« Reply #132 on: May 07, 2019, 08:11:00 pm »
Sorry guys, maybe I overlooked something and there is another combination...   ::)
uint[] ClearCode = { 0x3D1B58BA, 0x74B0DC51, 0x19495CFF, 0x257130A3 };
Can anyone test this with a v1.23 ?
Edit1:
Thanks wgoeo for the test. It seems i mixed the order...  :palm:  Endianess stuff...
So the correct order is:
uint[] ClearCode = { 0x19495CFF, 0x257130A3, 0x3D1B58BA, 0x74B0DC51 };
« Last Edit: July 21, 2019, 11:11:50 am by tv84 »
Offline TK
« Reply #133 on: May 07, 2019, 09:31:15 pm »
It doesn't work.  I downgraded to 1.12, connected using ssh, removed OptionsConf file to remove previous licenses, upgraded to 1.23 using SAFE MODE, tried applying new license code but it gives the same error.
The following users thanked this post: tv84
Offline frogblender
« Reply #134 on: May 23, 2019, 05:41:00 pm »
Quote from: TK
TK....  what's the latest with your GDS-1054B?   Is the hack working, and if so, what is your BW?
Offline TK
« Reply #135 on: May 23, 2019, 07:38:33 pm »
Quote from: TK
The last time I checked, I was able to measure frequency up to 300-350MHz, highly attenuated.  I don't have it anymore to continue the tests.
Offline wgoeoTopic starter
« Reply #136 on: July 20, 2019, 10:56:41 pm »
I think the correct order is
{0x19495cff, 0x257130a3, 0x3d1b58ba, 0x74b0dc51}
I checked with 1.24 (but not with a real scope), maybe it also works with 1.23.
« Reply #137 on: July 21, 2019, 02:03:33 am »
It seems you can get SSH back. Rename the attached file to debug.dbg, copy to a USB drive then do the same procedure. The password may have changed but you can probably add a command in the script to change it.
Edit: It's a startup script so you should reboot.
« Last Edit: July 21, 2019, 02:17:58 am by wgoeo »
Offline tv84
  • Country: pt
« Reply #138 on: July 21, 2019, 11:13:06 am »
Thankx! I corrected the initial post.
Offline frogblender
« Reply #139 on: August 21, 2019, 03:04:33 pm »
I got my unit today GDS-1054b, it came with firmware 1.19 so I downgraded to 1.18 and installed the *.lis files and verified they were working. I then upgraded to firmware 1.22 and all the options were still installed and work. Thanks to all for the help on this. Looks like you keep the added features with a firmware update.
@tonywood ... after modding your GDS-1054B...  is it still a 50Mhz scope?
Offline frogblender
« Reply #140 on: November 01, 2019, 05:29:14 pm »
 :wtf: :-//
I successfully generated the .lic files... but when I select each .lic file I get:
"To install this option you must use the GW USB key."
  Anyone have any ideas?  Help greatly appreciated.
(Both with 1.12 and 1.23.   I'd previously used the wrong ClearCode={xx} for my fw version...  which gave me a different error (something re: "check license!" or some such).   But I corrected the ClearCodes so I get past the "check license!".)
« Last Edit: November 01, 2019, 05:31:02 pm by frogblender »
Offline Wintel
« Reply #141 on: November 11, 2019, 03:53:31 pm »
New Frimware v1.26 and a new Fixed 4 Measurement Function Module license for GDS-1000B.
Offline wozzer
« Reply #142 on: December 05, 2019, 09:59:03 pm »
Has anyone confirmed whether the hack works with the latest firmware Ver. 1.26 ? I am about to go ahead and purchase my first scope...figured it was time to get one for home use after 35+ years in electronics ::)
Offline idolclub
« Reply #143 on: December 07, 2019, 05:10:07 pm »
Works with the latest firmware Ver. 1.26.
Offline wozzer
« Reply #144 on: December 07, 2019, 07:12:58 pm »
Thank you for confirming :)
Offline Mortymore
  • Country: pt
« Reply #145 on: February 07, 2020, 10:13:51 am »
On 2000E there's also the Function Module "Fixed 4 Measurement"
The firmware version installed on 2000E is 1.40 but I think this option came from a previous firmware version, I just haven't acknowledge his existence back then.
Anyone has this unlocked, or even know what does this do?
Thanks for any enlightenment.
Offline tv84
  • Country: pt
« Reply #146 on: February 07, 2020, 11:57:10 am »
Try to unlock it using the KG. The only thing the KG uses is the option_index not it's name. So you can try different indexes even if the name doesn't seem to be related.
The following users thanked this post: Mortymore
Offline planner29
« Reply #147 on: March 08, 2020, 01:36:08 pm »
New/updated brochure as of March 6, 2020 shows bus triggering/decode again! hmmm...  Also lists 200MHz 2 channel model.  New/updated datasheets and manuals also made available on same date.
Offline TK
« Reply #148 on: March 08, 2020, 01:55:53 pm »
links to the updated datasheet and manuals?
Offline idolclub
« Reply #149 on: March 08, 2020, 02:26:26 pm »
https://www.gwinstek.com/en-GB/products/detail/GDS-1000B
The following users thanked this post: TK
