Here is the .DTB.
It's inside the bootloader (offset 0xFA154) and, most probably, it's loaded by it.
Parsing:
000FA154 Magic: D00DFEED FDT File OK
000FA158 File Size: 00002868
000FA15C DT Struct Offset: 000FA18C
000FA160 DT Strings Offset: 000FC430
000FA164 Mem RsvMap Offset: 000FA17C
000FA168 Version: 00000011
000FA16C Last Compatible Vers: 00000010
000FA170 Boot CPU_ID: 00000000
000FA174 DT Strings Size: 0000058C
000FA178 DT Struct Size: 000022A4
000FA18C
000FA194 #address-cells = 0x00000001
000FA1A4 #size-cells = 0x00000001
000FA1B4 compatible = xlnx,zynq-7000
000FA1D0 model = Xilinx Zynq
000FA1E8 aliases
000FA1F4 ethernet0 = /amba@0/ps7-ethernet@e000b000
000FA220 serial0 = /amba@0/serial@e0001000
000FA244 i2c0 = /amba@0/ps7-i2c@e0004000
000FA270 chosen
000FA27C bootargs = console=ttyPS0,115200n8 ubi.mtd=5,2048 root=ubi0:rootfs rootfstype=ubifs ro earlyprintk mem=124M memmap=4M$0x7C00000 memmap=128M$0x08000000
000FA314 linux,stdout-path = /amba@0/ps7-uart1@e0001000
000FA340 cpus
000FA34C #address-cells = 0x00000001
000FA35C #size-cells = 0x00000000
000FA36C cpu@0
000FA378 bus-handle = 0x00000001
000FA388 compatible = arm,cortex-a9
000FA3A4 d-cache-line-size = 0x00000020
000FA3B4 d-cache-size = 0x00008000
000FA3C4 device_type = cpu
000FA3D4 i-cache-line-size = 0x00000020
000FA3E4 i-cache-size = 0x00008000
000FA3F4 interrupt-handle = 0x00000002
000FA404 reg = 00000000
000FA418 cpu@1
000FA424 bus-handle = 0x00000001
000FA434 compatible = arm,cortex-a9
000FA450 d-cache-line-size = 0x00000020
000FA460 d-cache-size = 0x00008000
000FA470 device_type = cpu
000FA480 i-cache-line-size = 0x00000020
000FA490 i-cache-size = 0x00008000
000FA4A0 interrupt-handle = 0x00000002
000FA4B0 reg = 00000001
000FA4C8 pmu
000FA4D0 compatible = arm,cortex-a9-pmu
000FA4F0 interrupt-parent = 0x00000002
000FA500 interrupts = 000000000000000500000004000000000000000600000004
000FA524 reg = F889100000001000F889300000001000
000FA540 reg-names = cpu0
000FA55C memory@0
000FA56C device_type = memory
000FA580 reg = 0000000010000000
000FA598 amba@0
000FA5A4 #address-cells = 0x00000001
000FA5B4 #size-cells = 0x00000001
000FA5C4 compatible = xlnx,ps7-axi-interconnect-1.00.a
000FA5FC ranges =
000FA608 linux,phandle = 0x00000001
000FA618 phandle = 0x00000001
000FA628 ps7-afi@f8008000
000FA640 compatible = xlnx,ps7-afi-1.00.a
000FA660 reg = F800800000001000
000FA678 ps7-afi@f8009000
000FA690 compatible = xlnx,ps7-afi-1.00.a
000FA6B0 reg = F800900000001000
000FA6C8 ps7-afi@f800a000
000FA6E0 compatible = xlnx,ps7-afi-1.00.a
000FA700 reg = F800A00000001000
000FA718 ps7-afi@f800b000
000FA730 compatible = xlnx,ps7-afi-1.00.a
000FA750 reg = F800B00000001000
000FA768 ps7-ddrc@f8006000
000FA780 compatible = xlnx,ps7-ddrc-1.00.a
000FA7B0 reg = F800600000001000
000FA7C4 xlnx,has-ecc = 0x00000000
000FA7D8 ps7-dev-cfg@f8007000
000FA7F4 clock-names = ref_clk
000FA820 clocks =
000FA854 compatible = xlnx,ps7-dev-cfg-1.00.a
000FA878 interrupt-parent = 0x00000002
000FA888 interrupts = 000000000000000800000004
000FA8A0 reg = F800700000000100
000FA8B8 ps7-dma@f8003000
000FA8D0 #dma-cells = 0x00000001
000FA8E0 #dma-channels = 0x00000008
000FA8F0 #dma-requests = 0x00000004
000FA900 arm,primecell-periphid = 0x00041330
000FA910 clock-names = apb_pclk
000FA928 clocks =
000FA93C compatible = xlnx,ps7-dma-1.00.a
000FA974 interrupt-names = abort
000FA9B0 interrupt-parent = 0x00000002
000FA9C0 interrupts = 000000000000000D00000004000000000000000E00000004000000000000000F00000004000000000000001000000004000000000000001100000004000000000000002800000004000000000000002900000004000000000000002A00000004000000000000002B00000004
000FAA38 reg = F800300000001000
000FAA50 ps7-ethernet@e000b000
000FAA6C #address-cells = 0x00000001
000FAA7C #size-cells = 0x00000000
000FAA8C clock-names = ref_clk
000FAAAC clocks =
000FAAC8 compatible = xlnx,ps7-ethernet-1.00.a
000FAAF0 interrupt-parent = 0x00000002
000FAB00 interrupts = 000000000000001600000004
000FAB18 local-mac-address =
000FAB2C phy-handle = 0x00000004
000FAB3C phy-mode = rgmii-id
000FAB54 reg = E000B00000001000
000FAB68 xlnx,eth-mode = 0x00000001
000FAB78 xlnx,has-mdio = 0x00000001
000FAB88 xlnx,ptp-enet-clock = ♠?k?
000FAB98 mdio
000FABA4 #address-cells = 0x00000001
000FABB4 #size-cells = 0x00000000
000FABC4 phy@0
000FABD0 compatible = micrel,ksz9031
000FABEC device_type = ethernet-phy
000FAC08 reg = 00000000
000FAC18 linux,phandle = 0x00000004
000FAC28 phandle = 0x00000004
000FAC44 ps7-gpio@e000a000
000FAC5C #gpio-cells = 0x00000002
000FAC6C clocks =
000FAC80 compatible = xlnx,ps7-gpio-1.00.a
000FACA4 emio-gpio-width = 0x00000040
000FACB4 gpio-controller =
000FACC0 gpio-mask-high = 0x00000000
000FACD0 gpio-mask-low = ☼►?☻
000FACE0 interrupt-parent = 0x00000002
000FACF0 interrupts = 000000000000001400000004
000FAD08 reg = E000A00000001000
000FAD1C linux,phandle = 0x00000005
000FAD2C phandle = 0x00000005
000FAD40 ps7-i2c@e0004000
000FAD58 bus-id = 0x00000000
000FAD68 clocks =
000FAD7C compatible = xlnx,ps7-i2c-1.00.a
000FAD9C input-clk = ♠?k?
000FADAC i2c-clk = 0x000186A0
000FADBC i2c-reset =
000FADD4 interrupt-parent = 0x00000002
000FADE4 interrupts = 000000000000001900000004
000FADFC reg = E000400000001000
000FAE10 xlnx,has-interrupt = 0x00000000
000FAE20 #address-cells = 0x00000001
000FAE30 #size-cells = 0x00000000
000FAE40 touch@38
000FAE50 compatible = edt-ft5x06
000FAE68 reg = 00000038
000FAE80 ps7-iop-bus-config@e0200000
000FAEA0 compatible = xlnx,ps7-iop-bus-config-1.00.a
000FAECC reg = E020000000001000
000FAEE4 ps7-pl310@f8f02000
000FAEFC arm,data-latency =
000FAF14 arm,tag-latency =
000FAF2C cache-level = 0x00000002
000FAF3C cache-unified =
000FAF48 compatible = xlnx,ps7-pl310-1.00.a
000FAF7C interrupt-parent = 0x00000002
000FAF8C interrupts = 000000000000000200000004
000FAFA4 reg = F8F0200000001000
000FAFBC ps7-ocmc@f800c000
000FAFD4 compatible = xlnx,ps7-ocmc-1.00.a
000FB008 interrupt-parent = 0x00000002
000FB018 interrupts = 000000000000000300000004
000FB030 reg = F800C00000001000
000FB048 ps7-scugic@f8f01000
000FB060 #address-cells = 0x00000002
000FB070 #interrupt-cells = 0x00000003
000FB080 #size-cells = 0x00000001
000FB090 compatible = xlnx,ps7-scugic-1.00.a
000FB0D0 interrupt-controller =
000FB0DC num_cpus = 0x00000002
000FB0EC num_interrupts = 0x00000060
000FB0FC reg = F8F0100000001000F8F0010000000100
000FB118 linux,phandle = 0x00000002
000FB128 phandle = 0x00000002
000FB13C ps7-scutimer@f8f00600
000FB158 clocks =
000FB16C compatible = xlnx,ps7-scutimer-1.00.a
000FB1AC interrupt-parent = 0x00000002
000FB1BC interrupts = 000000010000000D00000301
000FB1D4 reg = F8F0060000000020
000FB1EC ps7-scuwdt@f8f00620
000FB204 clocks =
000FB218 compatible = xlnx,ps7-scuwdt-1.00.a
000FB23C device_type = watchdog
000FB254 interrupt-parent = 0x00000002
000FB264 interrupts = 000000010000000E00000301
000FB27C reg = F8F00620000000E0
000FB294 ps7-slcr@f8000000
000FB2AC compatible = xlnx,ps7-slcr-1.00.a
000FB2DC reg = F800000000001000
000FB2F0 clocks
000FB2FC #address-cells = 0x00000001
000FB30C #size-cells = 0x00000000
000FB31C clkc
000FB328 #clock-cells = 0x00000001
000FB338 clock-output-names = armpll
000FB4B0 compatible = xlnx,ps7-clkc
000FB4CC fclk-enable = 0x0000000F
000FB4DC ps-clk-frequency = ☻bZ
000FB4EC linux,phandle = 0x00000003
000FB4FC phandle = 0x00000003
000FB518 ps7-smcc@e000e000
000FB530 #address-cells = 0x00000001
000FB540 #size-cells = 0x00000001
000FB550 clock-names = ref_clk
000FB570 clocks =
000FB58C compatible = xlnx,ps7-smcc-1.00.a
000FB5BC interrupt-parent = 0x00000002
000FB5CC interrupts = 000000000000001200000004
000FB5E4 ranges =
000FB5F0 reg = E000E00000001000
000FB604 xlnx,addr25 = 0x00000000
000FB614 xlnx,nor-chip-sel0 = 0x00000000
000FB624 xlnx,nor-chip-sel1 = 0x00000000
000FB634 xlnx,sram-chip-sel0 = 0x00000000
000FB644 xlnx,sram-chip-sel1 = 0x00000000
000FB654 ps7-nand@e1000000
000FB66C compatible = xlnx,ps7-nand-1.00.a
000FB690 reg = E100000001000000
000FB6A4 xlnx,nand-clk-freq-hz = ♣??
000FB6B4 xlnx,nand-cycle-t0 = 0x0000000F
000FB6C4 xlnx,nand-cycle-t1 = 0x0000000F
000FB6D4 xlnx,nand-cycle-t2 = 0x00000007
000FB6E4 xlnx,nand-cycle-t3 = 0x00000007
000FB6F4 xlnx,nand-cycle-t4 = 0x00000007
000FB704 xlnx,nand-cycle-t5 = 0x00000007
000FB714 xlnx,nand-cycle-t6 = 0x0000000F
000FB724 xlnx,nand-width = 0x00000008
000FB734 #address-cells = 0x00000001
000FB744 #size-cells = 0x00000001
000FB754 partition@0x0
000FB768 label = boot
000FB77C gw_part_type = 0x00000001
000FB78C reg = 00000000001C0000
000FB7A4 partition@0x1c0000
000FB7BC label = devtree
000FB7D0 gw_part_type = 0x00000002
000FB7E0 reg = 001C000000020000
000FB7F8 partition@0x1e0000
000FB810 label = env
000FB820 gw_part_type = 0x00000000
000FB830 reg = 001E000000020000
000FB848 partition@0x200000
000FB860 label = fpga-core
000FB878 gw_part_type = 0x0000000B
000FB888 reg = 0020000000080000
000FB8A0 partition@0x280000
000FB8B8 label = kernel
000FB8CC gw_part_type = 0x00000014
000FB8DC reg = 0028000000300000
000FB8F4 partition@0x580000
000FB90C label = rootfs
000FB920 gw_part_type = 0x0000001E
000FB930 reg = 0058000002E40000
000FB948 partition@0x33C0000
000FB960 label = user
000FB974 gw_part_type = 0x00000064
000FB984 reg = 033C000003C40000
000FB9A4 ps7-spi@e0006000
000FB9BC clock-names = ref_clk
000FB9DC clocks =
000FB9F8 compatible = xlnx,ps7-spi-1.00.a
000FBA18 interrupt-parent = 0x00000002
000FBA28 interrupts = 000000000000001A00000004
000FBA40 num-chip-select = 0x00000002
000FBA50 reg = E000600000001000
000FBA64 #address-cells = 0x00000000
000FBA74 #size-cells = 0x00000001
000FBA88 ps7-ttc@f8001000
000FBAA0 clocks =
000FBAB4 compatible = xlnx,ps7-ttc-1.00.a
000FBAE0 interrupt-names = ttc0
000FBAFC interrupt-parent = 0x00000002
000FBB0C interrupts = 000000000000000A00000004000000000000000B00000004000000000000000C00000004
000FBB3C reg = F800100000001000
000FBB54 serial@e0001000
000FBB68 clock-names = ref_clk
000FBB88 clocks =
000FBBA4 compatible = xlnx,ps7-uart-1.00.a
000FBBD4 current-speed = 0x0001C200
000FBBE4 device_type = serial
000FBBF8 interrupt-parent = 0x00000002
000FBC08 interrupts = 000000000000003200000004
000FBC20 port-number = 0x00000000
000FBC30 reg = E000100000001000
000FBC44 xlnx,has-modem = 0x00000000
000FBC58 ps7-usb@e0002000
000FBC70 clocks =
000FBC84 compatible = xlnx,ps7-usb-1.00.a
000FBCA4 dr_mode = otg
000FBCB4 interrupt-parent = 0x00000002
000FBCC4 interrupts = 000000000000001500000004
000FBCDC phy_type = ulpi
000FBCF0 reg = E000200000001000
000FBD04 xlnx,usb-reset = ????
000FBD18 ps7-usb@e0003000
000FBD30 clocks =
000FBD44 compatible = xlnx,ps7-usb-1.00.a
000FBD64 dr_mode = host
000FBD78 interrupt-parent = 0x00000002
000FBD88 interrupts = 000000000000002C00000004
000FBDA0 phy_type = ulpi
000FBDB4 reg = E000300000001000
000FBDC8 xlnx,usb-reset = ????
000FBDDC ps7-xadc@f8007100
000FBDF4 clocks =
000FBE08 compatible = xlnx,ps7-xadc-1.00.a
000FBE2C interrupt-parent = 0x00000002
000FBE3C interrupts = 000000000000000700000004
000FBE54 reg = F800710000000020
000FBE6C gw-lcdc@88800000
000FBE84 compatible = gw,gds-lcdc
000FBE9C reg = 8880000000002000
000FBEB0 num-of-layers = 0x00000003
000FBEC0 row-stride = 0x00000320
000FBED0 column-stride = 0x000005A0
000FBEE0 use-background = 0x00000000
000FBEF0 buffer-0-offset = 0x00000000
000FBF00 layer-0-data-width = 0x00000010
000FBF10 layer-0-offset = 0x00000000
000FBF20 vmem-baseaddr = ?
000FBF30 vmem-highaddr = ???
000FBF44 gds_video_params
000FBF5C pixel-component-format = RGB
000FBF6C pixel-component-layer =
000FBF80 active-layer = 0x00000000
000FBF90 videomode = 800x480
000FBFA4 800x480
000FBFB0 refresh = 0x0000003C
000FBFC0 xres = 0x00000320
000FBFD0 yres = 0x000005A0
000FBFE0 vmode = 0x00000000
000FBFF4 800x600
000FC000 refresh = 0x0000003C
000FC010 xres = 0x00000320
000FC020 yres = 0x00000708
000FC030 vmode = 0x00000000
000FC048 gds_wfrm_swctl
000FC05C compatible = gw,gds-wfrm-swctl
000FC07C seginfo-base = ☼??
000FC08C channel-source = ch1
000FC0CC gds_iofpga
000FC0DC compatible = gw,gds-iofpga
000FC0F8 iofpga-base = x??
000FC108 dvr0
000FC114 compatible = gds-iofpga,ad5207
000FC134 dev-id = 0x00000000
000FC144 create-dev-node = 0x00000001
000FC158 dvr1
000FC164 compatible = gds-iofpga,ad5207
000FC184 dev-id = 0x00000001
000FC194 create-dev-node = 0x00000001
000FC1A8 dvr2
000FC1B4 compatible = gds-iofpga,ad5207
000FC1D4 dev-id = 0x00000002
000FC1E4 create-dev-node = 0x00000001
000FC1F8 dvr3
000FC204 compatible = gds-iofpga,ad5207
000FC224 dev-id = 0x00000003
000FC234 create-dev-node = 0x00000001
000FC248 adc
000FC250 compatible = gds-iofpga,hmcad1511
000FC274 dev-id = 0x00000004
000FC284 create-dev-node = 0x00000001
000FC298 vco
000FC2A0 compatible = gds-iofpga,adf4360
000FC2C0 dev-id = 0x00000006
000FC2D0 create-dev-node = 0x00000001
000FC2E4 sensor
000FC2F0 compatible = gds-iofpga,lm95071
000FC310 dev-id = 0x00000007
000FC320 create-dev-node = 0x00000001
000FC334 led
000FC33C compatible = gds-iofpga,gds_led
000FC35C dev-id = 0x00000008
000FC36C create-dev-node = 0x00000001
000FC380 fram
000FC38C compatible = gds-iofpga,fm25cl
000FC3AC dev-id = 0x00000009
000FC3BC create-dev-node = 0x00000001
000FC3D0 fe
000FC3D8 compatible = gds-iofpga,gds1000b_fe
000FC3FC dev-id = 0x0000000E
000FC40C create-dev-node = 0x00000001
End of file!
