Author Topic: Possible GW Instek GDS-1000B hack  (Read 25429 times)
Offline rhb
Re: Possible GW Instek GDS-1000B hack
« Reply #50 on: December 03, 2018, 02:05:14 pm »
Just to give some idea of how extremely useful the SA function is here are some more screen dumps.
The H field probe is a 3-4 mm loop of copper wire wound on mandrels to be a push on fit to the probe tip and then insulated with several layers of heatshrink tubing.
The E field probe is a probe tip insulator with a bit of heatshrink over the probe tip.
So nothing fancy or expensive.  But safe to poke around without having to worry about causing a short.
I placed the probe about 1 cm from  the SMPS transformer of my GDS-2072E.  For the H field I rotated the probe to find the max and min orientations.  The E field was taken in the same location.
It's very easy to detect signals on ribbon cables, etc, though some shielding of the transformer fields would be needed to not have that dominate the spectrum.
Online toastedcrumpets
« Reply #51 on: December 18, 2018, 03:56:31 pm »
This will not work on 2000A because the S/N has a different format.
Nooooo! I've just got back to work after four weeks of paternity and found this disappointing news. Is there anything I can do to help fix this? I've cracked the case on the GDS-2074A scope I have and I'm probing for the JTAG/serial interface as we speak....
Offline Mortymore
  • Country: pt
« Reply #52 on: January 28, 2019, 06:44:25 pm »
Hope they are OK with this... if not let me know, please.
Summed the parts provided by wgoeo (reply #3) and tv84 (reply #47), and made a "soup" for my 2074E, since I was interested in the Spectrum Analyzer (SA) option.
The "soup" was named lis2.txt, and should be renamed to lis2.html
The SA option was installed with the latest firmware gds2000e_v1.38 (2019-01-26) on the scope.
As rhb explained "To access the SA you need to press the button in the lower right corner of the screen area below the small round button.", the OPTION button. Now I have a use for him.
Hope everything is alright, but it worked for me, as can be seen from the print screens attached.
Thanks for your work
PS: Sorry rhb I had to press AWG button. My scope didn't crash... until I go further, playing with Generators menus that the scope doesn't have.
« Last Edit: January 28, 2019, 07:10:04 pm by Mortymore »
The following users thanked this post: seronday
Offline pa3hfu
« Reply #53 on: January 30, 2019, 10:04:50 am »
I updated my 2104E to V1.38, but pressing the 'Option' button the scope says: Not supported for this model!
Offline Mortymore
  • Country: pt
« Reply #54 on: January 30, 2019, 10:55:47 am »
The OPTION button accessing the SA option, has no direct relation with the firmware version. You have to install the SA license.
Offline AC360
« Reply #55 on: January 30, 2019, 04:15:09 pm »
Does it work for GDS-1000B?
Offline AC360
« Reply #56 on: January 30, 2019, 04:28:04 pm »
Here is the new license generator for the current FWs of GDS1000B and GDS2000E, based on the wgoeo post (msg #3).
        private static void InstekKG(string serial)
            // This works for GDS1000B and GDS2000E
            string[] opt = { "PWR", "BUS", "SRH", "SGM", "BW100", "BW200", "BW300", "SA" };   // Prefixes: "DS1KB-"  or "DS2E-"
            // uint[] ClearCode = { 0x11111111, 0xABABABAB, 0x22222222, 0xCDCDCDCD };  // OLD -- GDS1000B (up to v1.18) and GDS2000E (up to v1.28)
            uint[] ClearCode = { 0x74B0DC51, 0x46E87CCD, 0x25E45D32, 0x515F007C };  // NEW
            serial = serial.Trim();
            int serial_int = Int32.Parse(serial.Substring(serial.Length - 4, 4));
            int pid_sum = 0;
            for (int i = 0; i < serial.Length - 4; i++)
                pid_sum += serial[i];
            for (int i = 0; i < opt.Length; i++)
                int[] a = new int[2];
                a[0] = (pid_sum << 24) | ((i << 8) & 0xF00);
                a[1] = (1 << 24) | ((serial_int << 8) & 0xFFFF00) | ((pid_sum >> 8) & 0xFF);
                for (int j = 0, k = -0x61C88647; j < 32; j++, k -= 0x61C88647)
                    a[0] += (int)((16 * a[1] + ClearCode[0]) ^ (a[1] + k) ^ ((a[1] >> 5) + ClearCode[1]));
                    a[1] += (int)((16 * a[0] + ClearCode[2]) ^ (a[0] + k) ^ ((a[0] >> 5) + ClearCode[3]));
                Console.WriteLine("DS1KB-{0}.lic / DS2E-{0}.lic - [{1:x8}{2:x8}]", opt[i], a[1], a[0]);
Those who prefer the javascript version can replace just the ClearCode constants in the script (I leave that as homework). The SA option was also added (only for the 2000E).
Edit1: Tested successfully by some members in DS2E and MSO equipments. This will not work on 2000A because the S/N has a different format.
Does it can upgrade the GDS-1000B to BW200 or BW300 MHz?
Offline Mortymore
  • Country: pt
« Reply #57 on: January 30, 2019, 04:51:34 pm »
@AC360
I don't think you can go further than 100MHz on GDS-1000B, since they are available with 50/70/100MHz bandwidth options.
Unless better opinion... I believe the code that tv84 provided, is able to work on the GDS-1000B, but only for the options that can be accepted by the scope. In that manner, the SA, 200MHz, 300MHz licenses among others, will probably not be accepted.
Be aware that the lis2.txt file I attached is "modded" for 2000E series. That was my homework as tv84 "ordered".  :-DD Do yours!
Online tv84
  • Country: pt
« Reply #58 on: January 30, 2019, 05:11:32 pm »
You passed the test, Morty. :)
The code works with the GDS-1000B version as stated in the code.
From what I remember, the licenses are generated based on the "option" index. So it's irrelevant the true name of the options.
In the GDS-1000B the BW options are  50/70/100MHz.
These are unlocking licenses, not HW upgrades!
Offline AC360
« Reply #59 on: January 30, 2019, 06:52:46 pm »
So the "SA" option only work with GDS2000E series?
Offline nctnico
« Reply #60 on: January 30, 2019, 06:57:57 pm »
Just try it. I don't think there is much difference in the firmware between the 1000B and 2000E series.
Offline Gazmon
« Reply #61 on: March 11, 2019, 01:01:16 am »
Are these hacks in reply 4 still working please
Offline nctnico
« Reply #62 on: March 11, 2019, 09:40:36 am »
You need to combine reply3 and reply47. This should create a working key generator you can run in your webbrowser.
Offline Gazmon
« Reply #63 on: March 11, 2019, 10:22:55 am »
I downloaded the file in reply 3 and followed the instructions, have renamed to an html file , when I opened in a browser it was just code text
How do I combine the code please? cant seem to get any key generator?
Wondered if anyone could maybe help me out in what im  doing wrong?
thanks for any info
« Last Edit: March 11, 2019, 05:27:32 pm by Gazmon »
Offline Gazmon
« Reply #64 on: March 11, 2019, 05:28:22 pm »
Bump..... anyone with a few tips
have a GDS 1000B
appreciate the help
Offline nctnico
« Reply #65 on: March 11, 2019, 06:01:27 pm »
Try a different browser or check whether you have visible extensions and your file is not actually called html.txt .
The following users thanked this post: Gazmon
Offline Gazmon
« Reply #66 on: March 11, 2019, 06:05:19 pm »
ok , but do I just need to combine the code in reply 4 and 47
in an html file?
Offline Gazmon
« Reply #67 on: March 11, 2019, 06:16:12 pm »
yep that worked, downgraded to 1.12 first... serial decode, waveform search, 200mhz (scope says its upgraded to this in system info), and segmented memory all installed
Bus button and search features have come to life
Upgraded back to 1.23 , all systems still good so far, needs checking to see whats there
cheers
« Last Edit: March 11, 2019, 08:32:36 pm by Gazmon »
Offline nctnico
« Reply #68 on: March 11, 2019, 09:30:59 pm »
Also thanks for acknowledging that this hack also makes serial decode available on the GDS-1000B. Did you also install the SA license? Pressing the 'option' button should bring up a menu with the spectrum analyser button.
Offline Gazmon
« Reply #69 on: March 11, 2019, 09:35:16 pm »
SA button, not sure I can get this on 1000b
correct me if I am wrong
the only option i didnt install was the `power analysis` is that worth having?
« Last Edit: March 11, 2019, 09:40:07 pm by Gazmon »
Offline Mortymore
  • Country: pt
« Reply #70 on: March 11, 2019, 10:03:24 pm »
... 200mhz (scope says its upgraded to this in system info)...
What scope exactly do you have?
Can you add a photo please? (or a screen capture of the System info, with the serial number blurred)
It's just that if you have a 1000B, I wasn't expecting it to reach 200MHz. I'm intrigued now  :-//
About the SA option (Spectrum Analyser) that nctnico is talking about, if it's available, you can access it with the "OPTION" button on the lower right corner near LCD screen (below "Menu off" button).
Offline Gazmon
« Reply #71 on: March 11, 2019, 10:20:05 pm »
photo attached, I have the 1102b 2 channel version
Serial decoding works but is not available for the parallel and SPI options it seems which is a bit disappointing
any idea what power analysis is, I didn't install this tbh
And the option button still does not do anything on my scope after the upgrades I did
Still pretty good scope after the hack
« Last Edit: March 11, 2019, 10:24:38 pm by Gazmon »
The following users thanked this post: Mortymore
Offline nctnico
« Reply #72 on: March 11, 2019, 10:33:19 pm »
Parallel is for digital channels only and SPI is only available on 4 channel models because you need 4 signals (clock, sel, MISO and MOSI) for SPI.
Offline Gazmon
« Reply #73 on: March 11, 2019, 10:45:28 pm »
Ok thats sorts that out, really just need to do a bandwidth check on the so called 200mhz that my scope claims to have now
being fairly new to all this what the easiest way to do this ?
any help appreciated
Offline Mortymore
  • Country: pt
« Reply #74 on: March 12, 2019, 12:18:06 am »
All I can tell is that power analysis is available for GDS-3000 Series, and it didn't work for me on the 2000E.
If that's just a matter of software or some hardware may be needed, I don't know. A current clamp for scope could be bought separately to deal with current, but I never look for intel on what could be holding the 1000B and 2000E so they can't have the power analysis option working.
