Author Topic: Possible GW Instek GDS-1000B hack  (Read 27024 times)
Offline tonywood
Re: Possible GW Instek GDS-1000B hack
« Reply #100 on: April 29, 2019, 09:36:26 pm »
Can someone send me an unhacked OptionConf file? I need to undo the hack for testing. Thank you
Or if anyone knows a way to undo the bandwidth option?
Thanks again
Offline Mortymore
  • Country: pt
« Reply #101 on: April 29, 2019, 09:49:24 pm »
See 4 posts back (Reply #96)
Basically, install a firmware that enables you to establishing an SSL connection to the scope and then delete the file OptionConf
Be very careful not to delete all files or the folder
« Last Edit: April 29, 2019, 09:53:01 pm by Mortymore »
Online TK
« Reply #102 on: April 29, 2019, 09:57:14 pm »
I received my GDS1054B today with firmware 1.23.  License generated by the latest script gives invalid license error.  Trying to downgrade to 1.12 but scope says I need to use SAFE MODE, but there is no documentation about it.  Does anyone know how to downgrade from 1.23 or what SAFE MODE means?
Online tv84
  • Country: pt
« Reply #103 on: April 29, 2019, 10:02:32 pm »
RTFM
https://www.eevblog.com/forum/testgear/possible-gw-instek-gds-1000b-hack/msg2007089/#msg2007089
The following users thanked this post: Deano76
Online TK
« Reply #104 on: April 29, 2019, 11:09:33 pm »
The new code does not work for firmware 1.23.  I managed to downgrade to FW 1.12 by using SAFE MODE:
(SAFE MODE Documentation): http://www.gwinstek.com.cn/upload/file/20181119051939962.pdf
0) Clear content of USB Drive
1) Copy firmware to root directory of USB Drive
2) Insert USB Drive to scope (when it is turned off)
3) Turn on scope and immediately start rotating the VARIABLE knob until SAFE MODE shows up.  It will recognize the firmware file and ask user to start installing it.  If there are multiple .upg files, it will show the first one, then ask if user wants to install current one or find next firmware
4) The manual says the scope will reboot automatically, but on mine, it just stopped after showing that NAND flash was completed.
5) Reboot scope and it should boot with the firmware version you copied to the USB Drive
This process is supposed to works also for bricked scopes.
After I downgraded to 1.12, I was able to use the code to enable all the options.
Now the scope is bricked again when I tried to upgrade to latest firmware 1.23
Will try to unbrick it using the SAFE MODE with 1.12 and try again.
EDIT: Using SAFE MODE I was able to reinstall FW 1.12.  Previously activated licenses are still valid.
EDIT2: upgrading to 1.23 does not work using the Utility option.  It works from SAFE Mode.
EDIT3: SAFE MODE allows you to select different firmware files to use for recovery.
« Last Edit: April 29, 2019, 11:52:57 pm by TK »
Online Fungus
« Reply #105 on: April 30, 2019, 07:57:44 am »
My GDS2204E goes over 300MHz with the 300MHz uphack. I'd expect the GDS1054B to also achieve the extra bandwidth.
Is that a good thing when you have such limited sample rate?
With 4 channels on the bandwidth will be higher than the sample rate.
Offline Mortymore
  • Country: pt
« Reply #106 on: April 30, 2019, 08:32:39 am »
... I need to use SAFE MODE, but there is no documentation about it.  Does anyone know how to downgrade from 1.23 or what SAFE MODE means?
You don't need to "go to China" to find manuals, firmware, software... just go to Download area @:
https://www.gwinstek.com/en-global/products/detail/GDS-1000B
The documentation for upgrading firmware is there, has everything else
The following users thanked this post: TK
Online tv84
  • Country: pt
« Reply #107 on: April 30, 2019, 10:16:45 am »
If anyone confirms this I could try to give it another look.
Online TK
« Reply #108 on: April 30, 2019, 10:43:21 am »
It was reported one month or so ago, but I don't know what was the outcome
https://www.eevblog.com/forum/testgear/possible-gw-instek-gds-1000b-hack/msg2293365/#msg2293365
Online tv84
  • Country: pt
« Reply #109 on: April 30, 2019, 10:59:05 am »
"don't know what was the outcome" <- that was the reason why I didn't pay attention
Online TK
« Reply #110 on: April 30, 2019, 01:42:41 pm »
I tested the BW after applying the 300MHz hack.
Test setup:
Signal Generator (Marconi 2024) --> SMA cable --> SMA_BNC --> 50ohm passthrough --> Scope input Channel 1 (1X attenuation)
Measured Frequency and Vpp
10MHz 1.2Vpp
100MHz 900mVpp (-3dB)
200MHz 280mVpp
250MHz 110mVpp
300MHz 48mVpp
350MHz 20mVpp (5mV vertical division setting)
Cannot measure reliable frequency at 400MHz and up.  I think officially it is a 100MHz front end.
« Last Edit: April 30, 2019, 01:56:21 pm by TK »
Offline Mortymore
  • Country: pt
« Reply #111 on: April 30, 2019, 03:41:45 pm »
@TK
What are the bandwidth limit options with the 300MHz BW hack?
For the 200MHz, options are 20,100,Full.
Note that GW-Instek has the 1000B with 50/70/100MHz bandwidth selections.
Online TK
« Reply #112 on: April 30, 2019, 06:41:12 pm »
@TK
For 300MHz, BW limitation options are 20, 100, 200, Full.
The following users thanked this post: Mortymore
Online TK
« Reply #113 on: May 01, 2019, 12:01:15 am »
I am not liking the refresh rate of the GDS1054B.  I am feeding an AM modulated signal and on both the Keysight 1000X and Rigol DS1054Z I can see a nice AM modulated waveform but on the GDS1054B I see single traces or at most 3-4 traces, but not the nice area filled trace like the other scopes.
The scope UI is very responsive like the Keysight, but I suspect the refresh rate is not near 50,000 wfm/s
Offline nctnico
« Reply #114 on: May 01, 2019, 08:20:31 am »
The update rate depends on the memory depth setting. But don't expect a very graded signal. The GW Instek goes from like 50% to 100% in order not to hide any rare signal occurence.
Offline rf-loop
  • Country: cn
  • Born with DLL21 in hand
« Reply #115 on: May 01, 2019, 08:56:28 am »
Do you mean using time base setting for look AM modulated RF carrier waveform or for look signal LF modulating envelope. Bit different cases.
Then, what ever scope,  these up to wfm/s speeds are mostly valid only with some special settings and signals (including also Keysight).  Very easy true is 50, or 500 or 5000 instead of 50kwfm/s or what ever.
Other question is that how important is beautiful image vs image what still give enough  information about signal under test.
Also in many scopes need some "know your equipment" before can find most optimal settings. (as can see example in tens or hundreds of junktube  nonsense "reviews" when the author's self-criticism and knowledge is not enough to assess whether it is published for the whole world or not. The world is drowning in a shit and in "tube" a small good "golden" part need find from huge amount of waste.)
« Last Edit: May 01, 2019, 09:15:01 am by rf-loop »
If practice and theory is not equal it tells that used application of theory is wrong or the theory itself is wrong.
Harmony OS
Online TK
« Reply #116 on: May 02, 2019, 09:45:24 pm »
After the hack my GDS1054B is freezing when I try to execute Self Cal.  I connect the BNC cable from the CAL output on the back to CH1, press VERTICAL and it hangs.  Is anyone else experiencing a similar behavior?  My unit came with 1.23, downgraded to 1.12, hacked, then upgraded to 1.23
Signal Path Compensation runs perfectly.
Offline Mortymore
  • Country: pt
« Reply #117 on: May 02, 2019, 10:40:02 pm »
The calibration process will take some 5 minutes per channel, or so, and probably during calibration the scope may not respond to buttons pressed (just guessing here).
Have you waited longer than 5 or 6 minutes for him to finish calibrating one of the channels?
Online TK
« Reply #118 on: May 03, 2019, 12:01:54 am »
Yes, I waited for 20-30 minutes or more
EDIT: Downgraded to 1.12.  Still not working.  It might be the 300MHz uphack.  Is there any way to remove the licenses?
« Last Edit: May 03, 2019, 01:10:44 pm by TK »
Offline nctnico
Online TK
« Reply #120 on: May 03, 2019, 03:46:34 pm »
False Alarm... it was a bad BNC cable   |O |O |O.  Self Calibration works OK on firmware 1.23 (and 1.12 as well).
Offline nctnico
« Reply #121 on: May 03, 2019, 03:48:12 pm »
Cut the cable in half and throw it away. BNC cables are plentyful and cheap on Ebay.
Offline Mortymore
  • Country: pt
« Reply #122 on: May 03, 2019, 05:25:32 pm »
If I recall correctly, I think Bob Pease once said that he marked bad components with a hammer.
If left lying around unmarked, they tend to be inserted again on a circuit.
The following users thanked this post: rf-loop
Offline rf-loop
  • Country: cn
« Reply #123 on: May 03, 2019, 05:29:12 pm »
Oh you want more bad crap BNC cables.  :-DD
Harmony OS
Offline nctnico
« Reply #124 on: May 03, 2019, 06:02:47 pm »
Well the cables I get from Ebay are way better then what I bought locally (unless you go for the utterly cheap ones on Ebay). Cables are consumables anyway.
