Just emailed Casey this:
OK, thanks for the Response Casey.
I have a number of these in the field that I support. Can you definitively confirm with an Engineer who is familiar with the inner workings of the scope, whether the death of the battery will cause the scope to lose it's MAC address. I also support some DPO/MSO4000 series, and would be very grateful if you could find out about these as well.
Thanks again,
Jay
Not much of an update, but what the hell...
Response from 1-4-2020
Hi Jay,
It’s definitely possible that the death of the battery could have caused the MAC address loss. A battery dying can cause the scope to lose system time which will mess with the other internal systems. I don’t know if you are planning on sending the scope in for repair, but our service team would be better at finding the cause of the issue.
"definitely possible" WTF does that mean?
So my next email:
Hi Casey,
The battery has been replaced and the time has been set correctly.
Are you saying that:
1. The MAC address is stored in non-volatile memory, that is powered by the battery when the power is off?
2. If yes, do the MSO/DSO4000 scopes store the MAC address the same way?
Thanks again for your help!
Jay
So far [crickets]
Using it's USB connection, I tried to brute force the MAC address using the first three octets that are assigned to Tektronix. I don't know whether it expects spaces, colons, or nothing, so I tried all three.
:MFG:MAC 08 00 11 79 22 91
:MFG:MAC 08:00:11:79:22:91
:MFG:MAC 080011792291
:PASSWord INTEKRITY (only)
:MFG:MODe (and using :PASSWord INTEKRITY)
:MFG:MODe (NOT using :PASSWord INTEKRITY)
None of those worked.
I also looked at some other scopes on my Asus router to see what other first three octets they use:
TDS3034B B041068 CODEX CORP 08:00:3E:01:02:03
That's odd - Codex.
TDS3014C C014072 TEKTRONIX INC 08:00:11:1E:C1:DD
What is strange (though not related to this thread) a TDS3054B with serial prefix B014XXX did not show up on my Asus router, but was working fine on Ethernet in any case. I tried a TDS3012B with serial prefix B027XXX and it behaved the same way.
Anyway, a few pics using a USB connection. The first, an MSO4K that's working correctly.
