Sorry to revive this old thread. I'm seeking for a 6 1/2 digits DMM for the home lab and got interested in second hand 34410As, which seems available on ebay for a reasonable price (other suggestions welcome). For obvious reason, the meter will be of better value if it's hackable. I downloaded the firmware (agt34411_instrument_rev243.zip) from Keysight website and start digging into it.
Basically, the xs file is a Motorola S file for the hex content, with tools like 010Editor, we can easily convert to the actual bytes in rom. binwalk indicates there is a Zlib compressed section, use -e to extract, and we get a vxworks image. With -a it turns out in the Agilent ASIC, the firmware runs on a big endian 32bits PowerPC core. Googling shows there is a tool
https://github.com/PAGalaxyLab/vxhunter can help me load the memory image in GHIDRA, and I noticed the image comes with a symbol table
. Searching the "Please load" quickly led to the _checkModelNumber__5IEIfcF routine
* FUNCTION *
undefined _checkModelNumber__5IEIfcFv()
undefined r3:1 <RETURN>
undefined4 Stack[0x4]:4 local_res4 XREF[2]: 004d4adc(W),
004d4b40(R)
undefined4 Stack[-0x10]:4 local_10 XREF[1]: 004d4acc(W)
_checkModelNumber__5IEIfcFv XREF[2]: initInstrumentEngine__5IEIfcFv:0
00a4d690(*)
004d4acc 94 21 ff f0 stwu r1,local_10(r1)
004d4ad0 7c 08 02 a6 mfspr r0,LR
004d4ad4 3d 80 90 00 lis r12,-0x7000
004d4ad8 a0 8c 00 0a lhz r4,offset DAT_9000000a(r12) <- UNKNOWN ADDRESS
004d4adc 90 01 00 14 stw r0,local_res4(r1)
004d4ae0 2c 04 23 5a cmpwi r4,0x235a
004d4ae4 40 82 00 3c bne LAB_004d4b20
004d4ae8 3c 60 00 96 lis r3,0x96
004d4aec 38 63 2c fc addi r3=>s_34410_FIRMWARE_00962cfc,r3,0x2cfc = "34410 FIRMWARE"
004d4af0 3c 80 00 96 lis r4,0x96
004d4af4 38 84 2d 0c addi r4=>s_PLEASE_LOAD_00962d0c,r4,0x2d0c = "PLEASE LOAD"
004d4af8 4b bc f7 29 bl updateVfdNow__FPCcT1 undefined updateVfdNow__FPCcT1()
004d4afc 48 0c 96 89 bl theMgr__19GandalfStateManagerSFv undefined theMgr__19GandalfState
004d4b00 38 80 00 00 li r4,0x0
004d4b04 48 0c 90 e5 bl enablePorRecall__19GandalfStateManagerFb undefined enablePorRecall__19Gan
004d4b08 3c 60 00 1e lis r3,0x1e
004d4b0c 60 63 84 80 ori r3,r3,0x8480
004d4b10 4b d6 e2 c9 bl spin__9SpinTimerSFi undefined spin__9SpinTimerSFi()
004d4b14 38 60 40 00 li r3,0x4000
004d4b18 4b ca 96 15 bl reboot int reboot(int __howto)
004d4b1c 48 00 00 24 b LAB_004d4b40
LAB_004d4b20 XREF[1]: 004d4ae4(j)
004d4b20 28 04 b6 43 cmplwi r4,0xb643
004d4b24 41 82 00 1c beq LAB_004d4b40
Although still not sure what the code is checking, as I hadn't got to figure out the memory mapping. I guess there is a 0x235a value in the calibration rom which is checked against, and it's possible the value can be changed in the vxWorks shell by the debug commands. But apparently, as there seems to be no secure booting, a trivial solution is to nop out the only code reference to this function in initInstrumentEngine__5IEIfcFv.
* FUNCTION *
undefined initInstrumentEngine__5IEIfcFv()
undefined4 Stack[0x4]:4 local_res4 XREF[2]: 004d4f30(W),
004d4ff4(R)
undefined4 Stack[-0x4]:4 local_4 XREF[2]: 004d4f2c(W),
004d5004(R)
undefined4 Stack[-0x8]:4 local_8 XREF[2]: 004d4f28(W),
004d5000(R)
undefined4 Stack[-0x10]:4 local_10 XREF[1]: 004d4f20(W)
initInstrumentEngine__5IEIfcFv XREF[2]: vxmain__FiPPc:0005c034(c),
00a661f0(*)
004d4f20 94 21 ff f0 stwu r1,local_10(r1)
004d4f24 7c 08 02 a6 mfspr r0,LR
004d4f28 93 c1 00 08 stw r30,local_8(r1)
004d4f2c 93 e1 00 0c stw r31,local_4(r1)
004d4f30 90 01 00 14 stw r0,local_res4(r1)
004d4f34 4b be 34 8d bl instance__10SoftRebootSFv undefined instance__10SoftReboot
004d4f38 4b b8 ca 6d bl subscribeEventBootHandlers undefined subscribeEventBootHand
004d4f3c 4b ff fb 91 bl _checkModelNumber__5IEIfcFv undefined _checkModelNumber__5IE
004d4f40 4b ff fb 0d bl _checkFlashType__5IEIfcFv undefined _checkFlashType__5IEIf <------------HERE
004d4f44 3f c0 00 c8 lis r30,0xc8
004d4f48 3b de 7c c0 addi r30,r30,0x7cc0
004d4f4c 48 08 9e 15 bl newScanController__Fv undefined newScanController__Fv()
I don't (yet) have the 34410A to verify this is feasible, but it looks promising.
BTW: who is Gandalf?
