Author Topic: UT61E+ computer access via CP2110?  (Read 1929 times)
Offline leifTopic starter
« on: September 24, 2021, 06:13:38 am »
I've just received a UT61E+ and was wondering if someone got the DMM connected via the supplied CP2110 UART bridge to his computer?
The communication seems to be bidirectional (see teardown) and it notices if the USB is plugged in (icon on LCD). But unfortunately it does not send any data (or I didn't find the correct settings).
I used the https://github.com/rginda/pycp2110 library to talk to the UART bridge, but never received any data - tried many different baud/parity combinations.
Anybody succeeded?
Leif
Online joeqsmith
Re: UT61E+ computer access via CP2110?
« Reply #1 on: September 24, 2021, 04:01:28 pm »
I'm not sure what you are asking.  Do you want to know if I can get the PC to work with the meter using UNI-Ts software or with some 3rd party program?   I have not tried to use their software but can easily set it up if you like to see if I run into any problems.
« Reply #2 on: September 24, 2021, 09:32:01 pm »
thanks for the response. Sorry, I wasn't really precise with my question: I'm looking for a solution to get the measurements of the DMM accessible within Linux/Python-scripts. I guess the supplied vendor software under Windows works but does not allow automated measurements.
Thanks
Leif
Online joeqsmith
« Reply #3 on: September 24, 2021, 09:57:25 pm »
That makes more sense.  I use LabView for all of my automation so I won't be of any help.
Offline ledtester
« Reply #4 on: September 24, 2021, 11:15:14 pm »
Thanks
Leif
There is HKJ's TestController:
https://www.eevblog.com/forum/testgear/program-that-can-log-from-many-multimeters/
or just google for ut61e and python:
https://github.com/pklaus/ut61e_python
« Reply #5 on: September 26, 2021, 07:04:41 pm »
thanks for the links but they do NOT support the 61E+ model. But I've started to reverse engineer the protocol by attaching an USB sniffer on windows and got quite far.
See first code here:
https://github.com/ljakob/unit_ut61eplus
So for anybody interested, please join the effort.
Leif
« Reply #6 on: October 03, 2021, 07:29:24 pm »
It's working nicely - there's also a MQTT bridge that forwards the measurements
It should work also for other models:
    UT60BT
    UT61B+
    UT61D+
    UT161B
    UT161D
    UT161E
with minor changes. But couldn't test.
The following users thanked this post: ledtester
Offline Dave_g8
« Reply #7 on: May 14, 2024, 08:16:08 am »
Thank you very much for generating the python code package.
I have used the Serial Bluetooth Android App with the UT60BT and all supported commands and responses appear to work as expected (see below).
For information, the comment in the source code relating to the "sendCommand" is a simplified method of calculating the checksum, where 379 (DEC) is the SUM of the first 3 bytes (HEX) "AB CD 03”.
“cmd = cmd + 379 # don't ask it's from the java source”
2202283-0
2202271-1
2202277-2
« Last Edit: May 14, 2024, 08:26:19 am by Dave_g8 »
Offline Adrian_Arg.
  • Country: ar
« Reply #8 on: May 14, 2024, 10:42:27 am »
In my case, when I am going to use it I restart the PC, and when it finishes starting I launch the unit software, and it works correctly and on the other PC I do not have that problem, but on mine it is due to the conflict with some drivers reddragon headphones
