Author Topic: Power Supply  (Read 2633 times)
Offline aparlettTopic starter
Power Supply
« on: March 28, 2013, 12:45:10 pm »
Hey Guys
Looking for a cheap power supply that has +/- output round $100 mark? nothing too high powered just to play around with precision op-amps.
any suggestions will be a great help.
thanks
Offline eevblogfan
Re: Power Supply
« Reply #1 on: March 28, 2013, 12:53:12 pm »
hey
Why dont you use cheap ass 12~ 30V 9W or so wall wart and use voltage splitter creating virtual ground using Lm358 one pot and pair of NPN and PNP power transistors ?  I don't have the schematic now  :palm:
pleas some one give him the proper schema  :scared:
all I can find now is that ( should be good anough as op amp baiasing supply )
http://www.circuitstoday.com/wp-content/uploads/2008/08/voltage-splitter-using-opamp.JPG
Cheers :)
Offline IanB
Re: Power Supply
« Reply #2 on: March 28, 2013, 12:56:28 pm »
If you only need a few milliamps than back-to-back 9 V batteries will work fine.
Re: Power Supply
« Reply #3 on: March 28, 2013, 01:00:53 pm »
Im going to uses two 9 volt batteries for now but would like to have a proper supply as im going to be suing it alot more in the future.
Offline eevblogfan
Re: Power Supply
« Reply #4 on: March 28, 2013, 01:21:57 pm »
hey
Schema is the first photo and the final circuit I've built ( including Lm317 , but not really needed I think ><" )
Re: Power Supply
« Reply #5 on: March 29, 2013, 05:34:37 am »
thanks that looks pretty good to get me through until i can get a better supply
Re: Power Supply
« Reply #6 on: March 29, 2013, 05:43:49 am »
any suggestions as off the self ones i can start looking into as well or are they out of price range
Offline eevblogfan
Re: Power Supply
« Reply #7 on: March 29, 2013, 09:16:43 am »
I am afraid the "good " one ( e3630A) is out of range unless you can get it locally for that 100~120$ ( which I don't think you can , but give it A chance :P )
I don't know any other +/- supply to recommend though I am absolutely sure there are few more out there :P
