Currently I have a WAVETEK FG3B function generator which is not bad but it's a little bit too noisy for my Audio usage (specially for the square wave)
I need at least:
- frequency range until 20 MHz
- good Frequence Accuracy (<0.5% )
- output range until 5vpp
- low distortion sin wave
- small overshot for square wave
My budget is arround 250€ (very max 300)
As new instrument I found two nice generators by Rogol and Siglen
- Siglent SDG1000
- Rigol DG1022
For Old instrument :
- HP 3325B
- HP 8165A
I know that all instrument I have listed above are more or less fitting my needs but what will be your advice ? better a new or an old instrument? do you have maybe other good suggestions?
Thanks for your help.
Regards,
Alex
