I guess it's a tricky one to specify accurately, as you can only specify the battery capacity as it supports so many voltages. It is a bit disappointing though!
This is exactly the reason why specifying not charge, but energy capacity, in Watt-hours, and conversion efficiency at different output voltages, is the right and universal way of doing it. Having these two, the customer can adequately compare different powerbanks and estimate how long they are going to last in a particular scenario.
It reports 2.3-2.4A of current draw at 15V, so on that basis (40Ah * 3.7V = 148W)
Make sure you make no mistake in units calculation to avoid misunderstanding the concepts of power, current, charge, and energy. Multiplying Ah and Volts won't yield Watts:
1 A = 1 C / 1 s [current, aka charge over time]
1 W = 1 J/s [power, aka energy over time]
1 A * 1 V = 1W
1 A*h = 1 A * 1 h = 1 A * 3600 s = 3600 C [charge]
1 W*h = 1 A*h * 1 V = 1 W * 1 h = 1 W * 3600 s = 3600 W*s = 3600 J [energy]
