Author Topic: Presenting my new software for the SMA Spectrum Analyzer 138MHz-4.4GHz  (Read 40023 times)
Offline Fraser
Re: Presenting my new software for the SMA Spectrum Analyzer 138MHz-4.4GHz
« Reply #25 on: August 30, 2016, 11:06:52 pm »
Sorry I have not provided any feedback on this software yet. I am buried in thermal camera repairs so have not had time to play with it yet.
I will provide feedback as soon as I get some spare time.
Many thanks for your hard work on this
Fraser
Offline Bicurico
  • Country: pt
    • VMA's Satellite Blog
« Reply #26 on: August 31, 2016, 09:35:49 am »
Fraser
I read your post about the thermal imaging repair... Now THAT seemed to me like hard work! I found it particularily cool that you have acess to X-ray machine.  :-+
Regards,
Vitor
Offline Fraser
« Reply #27 on: August 31, 2016, 10:00:53 am »
If you like my use of X-Ray, I produced a thread full of pictures that I have taken with both my original and newer Faxitron MX-20 machines.
https://www.eevblog.com/forum/projects/the-x-ray-image-thread-by-aurora-various-electronics-via-x-ray-imaging/msg748531/#msg748531
Fraser
Offline nctnico
« Reply #28 on: September 08, 2016, 10:40:52 pm »
I tried to run the software but Windows says it isn't a valid .EXE file! Also the .exe is only 35kB and that seems a bit low. I'd expect an exe of several MB at least.
Offline Bicurico
  • Country: pt
« Reply #29 on: September 11, 2016, 11:50:46 am »
The executable inside the ZIP Archive is indeed only 35kB! It was done in Visual Studio .net 2012 using VB .net. It does not require any installation or additional files. The little data it needs to store (currently just the activation code and the serial port) resides in HKEY_CURRENT_USER\SOFTWARE\SMA Simple Spectrum.
You do need to have a modern Windows version with .net Runtime installed. I have not tested the executable in older Windows releases! Not sure if it runs in Windows XP.
If you get an invalid *.EXE file error, you are either using an older Windows version, don't have .net installed or have a corrupt download.
Regards,
Vitor
Offline nctnico
« Reply #30 on: September 11, 2016, 01:07:28 pm »
Aha, ofcourse I tried to run it in XP! Does it run out of the box on Windows 10 (32 bit)? If not what .net installer do I need to install first?
Offline Bicurico
  • Country: pt
« Reply #31 on: September 11, 2016, 01:14:24 pm »
It certainly run out of the box on my Windows 10 @ 32bit tablet (x86).
It is actually nice to use the software on a tablet with an OTG-adapter, as you get a really small setup. It's what I use when travelling.
Regards,
Vitor
Offline R005T3r
« Reply #32 on: September 11, 2016, 01:43:13 pm »
The link on filedropper.com don't redirect correctly.
Anyway, thanks....
Offline Bicurico
  • Country: pt
« Reply #33 on: September 11, 2016, 03:17:17 pm »
The link on my blog (last post) works OK: http://www.filedropper.com/smasimplespectrumanalyzer-2016-08-31
Just tested it myself and the zip contains an executable which opens fine.
Regards,
Vitor
Offline R005T3r
« Reply #34 on: September 11, 2016, 04:51:15 pm »
Confirmed. It works.  :) :-+
Offline nctnico
« Reply #35 on: September 11, 2016, 06:05:47 pm »
Unfortunately my SMA SA does absolutely nothing with the software  :'( There is no signal output at all when used as a generator.
There is also no indication whether if it has the right firmware, whether it is communicating OK and so on.
« Last Edit: September 11, 2016, 06:11:27 pm by nctnico »
Offline Bicurico
  • Country: pt
« Reply #36 on: September 11, 2016, 06:09:04 pm »
As far as I know, there is only one firmware, or, to be correct: all FW version identify themselves as "119" (literally sending one Byte &D119)...
Which device do you have? Did you configure the correct COM-port? Did you connect a signal in the IN-port?
With my software there is literally nothing to install or configure: just start it and select the correct COM-port. Hit the START button on the first tab and you should see something.
Send me a screenshot!
Regards,
Vitor
Offline nctnico
« Reply #37 on: September 11, 2016, 06:12:00 pm »
I want to use it as a generator.
Offline nctnico
« Reply #38 on: September 11, 2016, 07:38:22 pm »
I tried a signal from an RF generator connected to the input as well but still no-go.
Edit: I think my unit is broken. The original software shows nothing as well. I'm going to resurrect my own signal generator board; this is turning into a time sink and all I want to do is do a quick sweep to see if my spectrum analyser is working.
« Last Edit: September 11, 2016, 08:02:32 pm by nctnico »
Offline Bicurico
  • Country: pt
« Reply #39 on: September 11, 2016, 07:50:33 pm »
The signal output doesn't show anything on the screen: you just activate it with the SET button and that's it.
Even without a signal present on the input connecter, the spectrum should show the noise floor.
Perhaps your device is seriously broken? Does it work with WinNWT?
Regards,
Vitor
Offline nctnico
« Reply #40 on: September 11, 2016, 08:03:14 pm »
The original software (which is an utter mess indeed) does nothing as well.
Offline Bicurico
  • Country: pt
« Reply #41 on: September 11, 2016, 08:05:54 pm »
Sounds like a broken device.
If you go to the Device Manager, do you see the COM-port?
Does the green LED turn on, when you connect the device to the USB port?
Do you get an error message with my software? Did you select the correct COM-port?
Regards,
Vitor
Offline nctnico
« Reply #42 on: September 11, 2016, 08:31:11 pm »
Yes, yes and yes. The original software (running on Linux) also shows the firmware version so I guess the communication is working. I'm going to return it.
Offline Bicurico
  • Country: pt
« Reply #43 on: October 02, 2016, 03:29:35 pm »
Just updated my software with a new function: it now shows the RWB value.
Download link on my blog, together with a small explanation of why you select Samples instead of RWB.
Regards,
Vitor
Offline bitseeker
« Reply #44 on: October 03, 2016, 10:47:56 pm »
Thanks for the update, Vitor. You meant RBW, correct?
I TEA.
Offline Bicurico
  • Country: pt
« Reply #45 on: October 04, 2016, 06:16:05 am »
Yes.  :palm:
The following users thanked this post: Heartbreaker
Offline Bicurico
  • Country: pt
« Reply #46 on: October 04, 2016, 11:22:32 pm »
Today I made some major improvements with the graphics.
Download available at http://www.filedropper.com/smasimplespectrumanalyzer-2016-10-04
Regards,
Vitor
Offline Bicurico
  • Country: pt
« Reply #47 on: October 05, 2016, 11:57:03 am »
Here is a video showing of the latest software release. The video shows the ASTRA 19.2E satellite spectrum.
https://youtu.be/4edLLw_7NRg
Regards,
Vitor
Offline vordme
« Reply #48 on: October 09, 2016, 05:11:26 pm »
Hi Vitor,
congratulations for this nice job..
here testing 430 Mhz antenna
Offline Bicurico
  • Country: pt
« Reply #49 on: October 09, 2016, 06:24:05 pm »
Thanks for sharing!
Nice to see some use for the SMA Simple Spectrum Analyzer!
Question: is the software easy enough to understand the different functionality or is a manual required?
Regards,
Vitor
