I've acquired a DHO942s that will be put on a GRIFEMA Monitor stand.
The USB-c and plan cables can be put nicely in the Vesa arm.
But what are you guys using for storing the probes?
Ideally, I would like to put all four probes on the scopes bnc's and, with a swift manoeuvre, get the number needed of probes to the circuit. Then, after use, put it neatly away.
