Author Topic: 87V non-contact frequency?  (Read 649 times)
Offline brocklesTopic starter
« on: March 08, 2022, 09:27:50 am »
When on frequency mode on the 87V, if the meter itself is leant on a phone charger lead but the test leads are on nothing, it shows 50Hz. Is this normal?
Offline rsjsouza
  • Eternally curious
    • Vbe - vídeo blog eletrônico
Re: 87V non-contact frequency?
« Reply #1 on: March 08, 2022, 11:57:03 am »
No, this is not right; it should be reading 60Hz.  :P
Just kidding... A multimeter with an open input has enough sensitivity to capture noise from the environment around you. The supply noise may be enough to be picked up and measured by the 87V.
The following users thanked this post: JohnG
« Reply #2 on: March 08, 2022, 12:09:13 pm »
Seeing that initial no, this is not right made my heart skip a beat for a moment then!!
Thank you very much for clearing that up for me.
