Author Topic: Tektronix TDS 5104 .iso image  (Read 6697 times)
Offline GridWorkTopic starter
« on: January 25, 2023, 09:06:39 pm »
I have an older Tektronix TDS 5104 at work that the hard disk died on. No problem buying a new drive, but I cannot find any of the software install discs for the scope. Does anyone out there have the original discs that would be willing to copy, or an iso image of the drive that I could restore to a new drive? I figure that this is a long shot, but this is the best place to ask.
Offline d37duck
Re: Tektronix TDS 5104 .iso image
« Reply #1 on: January 27, 2023, 12:14:00 am »
Lets see if I can help
Let's see if I can help.  You need a system restore disk for a Tek TDS5104 scope?  Not a TDS5104B, the B makes a difference.
Tek TDS5000 scopes use one of two operating systems (OS): Windows Mullennium or Windows 2000.  Do you remember what operating system your TDS5104 used?
Tek TDS5000 scopes use one of two types of motherboard.  The early scopes with serial number B01xxxx through B02xxxx (and maybe higher) use Intel D810E2CB motherboards.  I don't believe this motherboard supports Windows 2000, not enough memory.  The later scopes with higher serial numbers used Intel motherboards with D815 chipsets.  I don't know the Intel model number.
With two versions of OS and two types of motherboard, Tek made 6 OS Restore CDs for TDS5000 scopes.  The part numbers are 063-3509-00 to 063-3509-05.  The first 4 are Windows Mellennium (-00 to -03) the last 2 are Windows 2000 (-04 and -05).  The first 3, part numbers (-00 to -02) support the early Intel 810E2CB motherboard.  I think the last 3, part numbers (-03 to -05) support the late motherboard with Intel D815 chipset.  Part number -03 is for Windows Mellennium with the later motherboard.  It's not clear how the scope's serial number tracks these changes.
The OS restore disk doesn't contain the scope's application software.  The good news is, this stuff can be downloaded from Tek's website for the scope's serial number and installed after the OS is installed.
I have an OS restore disk part number 063-3509-01. I think it supports a TDS5000 scopes with seral number B01xxxx and above.  I've attached the installation instructions.  I'll give you an ISO copy (all 600MB, it’s too big to email or post) if you tell me how, with the hope you do me a favor.  Tell me the details of your scope; seral number (the B and first 2 digits is enough), motherboard type, and post or email me a copy of the motherboard's BIOS.
The reason I want the BIOS is, Tek customizes the bios with splash screens and a tag message that tells the application software’s installation press what the instrument is.  No tag no install.
You can copy of the BIOS by unzipping the attachment and running the portable executable program 'Universal BIOS Backup ToolKit 2.0.exe'.  Instructions are included, the program only reads to a specified file.  The output file will be about 500KBs that can posted or emailed.
« Reply #2 on: January 30, 2023, 04:39:17 pm »
The model is a plain TDS 5104, SN B0207__
In BIOS the motherboard is showing up as an EA81520A.
It came loaded with Windows 2000 embedded, the product serial keys for both Windows and Tektronix software are still intact.
« Reply #3 on: January 31, 2023, 12:18:44 pm »
Looked into the scope more, looks like the internal display is dead as well, external monitor port works. It's not looking good for it, not sure it is worth doing more on.
Offline d37duck
« Reply #4 on: February 01, 2023, 07:44:05 pm »
Thanks for the information.  The BIOS Version number shows your motherboard is in the D815 family.  I guess the internal display doesn't work if the system doesn't have its device driver.  The device driver is on the broken disk drive.
I have the remains of a TDS5104 SN B020452 with system disk drive.  It came with a D810E2CB motherboard. The motherboard died from bad buck regulator capacitors in the CPU's core power supply.  I replaced that motherboard with a D815EFV.  It should be like the motherboard in your scope. The new motherboard boots from the original disk. When Windows Mellennium starts, the icons for Tektronix Apps are on the display.  I don't know if the scope could be fully functional because the PC Interface board has a bad signal processing chip, IBM PowerPC405GB. In the eeVblog there's a thread from a guy who tried to replace that chip.  At the end, he gave up and bought another board.
See the attached photo of my D815EFV motherboard installed in a scope SN B02xxxx aluminum back panel. Notice on the bottom right side, the LAN connector doesn't fit the hole the aluminum back panel. Does your scope look like this?
My D815EFV motherboard didn't come from Tektronx. It doesn't have a the tek BIOS with the tag that indicates it’s a TDS5000 series scope. It has splash screens displayed while the BIOS is setting up from Intel.  Does your scope display splash screens from Tektronix or Intel?
My reason for the questions is, did your scope get a tek factory update to the D815 family motherboard or did some one local update the motherboard like I did.  If the motherboard is a local update without the tek BIOS you may not be able to use OS Restore Disks.  No tag no install; but when I look at my OS Restore Disk, I don’t see Install Shield so maybe it will install.
A reliable solution is to image a working disk and make a clone disk from the image for your scope. KEEP THE IMAGE. Making a writing the image, to a disk you will use as a clone, works well on a second computer with USB, preferably USB 3, via disk interface.  See the pdf attachment for an example.  I bought this gizmo on Ali Express, or eBay, for $12.  There is no software required to connect the disk, plug your disk onto the gizmo and connect the USB cable to your computer.  If the power drain of the disk is too large for USB, attach the included 12V wall wort.  Your attached disk will show up in the ‘This PC window’.
You will need software to make an image and write the image to your clone disk.  I use HDClone, I had to buy it.  HDClone can write its image to disks with different numbers of cylinders and tracks.  For Acronic, the numbers for both cylinders and tracks need to be the same or larger.  Clonezilla is free and has resent updates, it may work but you have the same issues about disk type as Acronic.
I make images of all of my disk drives and file copies of the BIOS.  The disk image I have for the TDS5000 system disk is ~3GB.  I should fit on a DVD which I can snail mail to you.
« Reply #5 on: February 02, 2023, 02:00:55 pm »
The scope boots up showing the Tektronix logo (on an external monitor). I seem to remember the internal monitor working prior to any drivers being loaded, able to get to bios and do the typical 2000's computer stuff.
If it were my personal scope, I would be all in at fixing it, but since it isn't, I will have to see if management wants to bother repairing it. If so, I'll still need to get a hard-drive and then start the software install process.
I did poke around on the Tek website for the 5104 and did see a couple of 90MB files that I suspect are the scope software.
I will keep you in mind if I go down the path of fixing this bugger. Thanks for the input so far!
Offline d37duck
« Reply #6 on: February 02, 2023, 06:12:04 pm »
Before buying a disk, look inside your scope to see what form factor the disk your replacing is.  Tek used 2.5" IDE interface disks in early scopes and switched to 3.5" in later versions.  With a seral number like B02xxxx without a B on the end, the disk is likely 2.5" with IDE interface.  I've seen 40GB in 2.5" disks, but 80GB and above are likely 3.5" or a SATA interface disk that won't fit.  The disk I have is a 6.1GB, 2.5" IDE interface disk.  Is the attached photo.
« Reply #7 on: February 02, 2023, 07:31:48 pm »
I've already had the scope apart and know that it was a 40GB Hitachi 2.5" drive that died. If it had been a 3.5, I would have had a replacement on hand. :D
Offline calibrationfixture
« Reply #8 on: February 02, 2023, 07:51:00 pm »
My TDS5104 (B04xxxx) had a 20 GB HDD and a TDS7404B (B02xxxx) and TLA715 (B03xxxx) had 40 GB HDD's. All were Hitachi Travelstar 2.5" IDE 44-Pins.
I bought as replacements:
https://www.ebay.com/itm/263570798218
All working fine.
Greetings,
Calibrationfixture
« Last Edit: February 02, 2023, 08:02:26 pm by calibrationfixture »
Offline langlv
« Reply #9 on: May 03, 2023, 12:08:07 pm »
Hello D37duck,
I have a flacky TDS5104 B020382 with MB D819E2CB, bios E210882. The 10.6GB disk no longer works. I will be more than happy to receive your ISO for WinMe.
I will make a bootable USB to dump the bios content for yiur record.
Many thanks in advance,
Lang
Offline d37duck
« Reply #10 on: June 22, 2023, 02:41:44 pm »
Hi langlv,
It's nice to hear from someone.  There was no activity on this thread for months, so I stopped looking.  If you click on my handle, it opens my profile where I listed an email address.  If you send me email we can exchange files up to a few megabytes.
For the BIOS image, download the tool I posted a link for, put the BIOS image into a Zip or Rar archive, and attach it to an email to me.
For the disk image there are a few issues:
(1) I think I can use Gmail to make a virtual disk and load a 3GB disk image, then give you a link.  I haven’t done this before.  If you know of instructions for doing this, email me a link to then.   When I have the image online, I'll email you a link.
(2) You will need a tool to write the image to your new hard drive.  To do it on the scope, you need a self-booting tool that works on you D810 motherboard an supports the 3GB disk image.  I think the HD Clone tool I listed will do this but you have to buy it and it’s expensive.
(3) I would attach the new hard disk to a PC, make an active partition, format the partition in FAT32, and write the disk image.  I listed some tools for use with a PC like Clonezilla (https://clonezilla.org/downloads.php).
Tell me what tool you want to use.
Regards,
Offline Joebeazelman
  • Country: yt
« Reply #11 on: November 17, 2023, 06:30:37 pm »
I have both a TDS5054 and a TLA5052 (?) which is being shipped. Both of them use the same MOBO unfortunately which is the older variant. I started another thread about replacing the CPU board (Tektronix euphemism for plain old motherboard to save time and money).
https://www.eevblog.com/forum/repair/help-with-replace-tektronix-tla5000tds5000-motherboard/msg5172882/#msg5172882
Offline charlyd
« Reply #12 on: December 04, 2023, 09:33:31 am »
Hi why not buy a ssd and a 44pin mSata to Pata adapter for this 32GB ssd.
this speeds up your boot time enormous.
« Last Edit: December 04, 2023, 09:35:41 am by charlyd »
Offline alexe91
« Reply #13 on: July 03, 2024, 11:19:46 pm »
I am also looking for a 063-3509-xx System restore disk for a TDS5104 (Non-B) for a system originally using a Windows ME installation and has a D810E2CB motherboard, if anybody has an iso of this disc or anything, it would be greatly appreciated
Offline coromonadalix
« Reply #14 on: July 03, 2024, 11:35:21 pm »
try contacting @langlv   he had iso of tds5k
Offline alexe91
« Reply #15 on: July 08, 2024, 05:10:56 pm »
Just as a note for anyone looking, I do have a copy of the 063-3509-04 Win2k OS Restore disks, confirmed working on a TDS5104 with an Intel DB815 mobo that I would be happy to create an .iso of if anyone needs it.
Offline elantra
  • Country: cn
« Reply #16 on: July 29, 2024, 12:06:13 pm »
it's very nice for hear that u have win2k version!!
hope u could share with us...
btw, my tds5054 is 815 motherboard, with tualatin celeron 1.2GHz,I tried to add another 256Mb memory, this machine is quite picky about the memory, finally, pc133,cl=2 works..
Offline matsmyth
« Reply #17 on: August 29, 2025, 05:01:18 am »
@d37duck, @langlv do either of you still have an iso for a tds5104B B023XXX
