Author Topic: KEYPAD for R&S SFU 2110.2500.02  (Read 2844 times)
Offline OliverWirthgTopic starter
  • Country: cz
« on: March 13, 2024, 12:22:43 pm »
Is it possible to buy a new rubber keypad for the R&S SFU 2110.2500.02 somewhere? I have been checking ebay on a regular basis, but to no avail. Does anyone have an idea who to approach? Respectively, is it possible to search under a name other than "keyboard on R&S SFU"? Thank you for any help!
Offline wraper
  • Country: lv
Re: KEYPAD for R&S SFU 2110.2500.02
« Reply #1 on: March 13, 2024, 12:32:03 pm »
For such things chances are essentially zero unless manufacturer is willing to sell it to you. What's the problem with original one?
  • Country: cz
« Reply #2 on: March 13, 2024, 05:36:59 pm »
There is one missing on the original buttons. The others work unreliably (worn conductive surfaces).
Offline wraper
  • Country: lv
« Reply #3 on: March 13, 2024, 08:54:49 pm »
Poorly conductive surface usually can be restored by washing with detergent and if it's not enough, a little bit of sanding with fine sandpaper. Resistance can be checked with multimeter.
Offline vishaldotgupta
  • Country: in
« Reply #4 on: December 02, 2025, 01:09:57 pm »
 :phew: do you still need sfu pad
