Author Topic: uCurrent accuracy - what am I missing?  (Read 9094 times)
Offline SaintGimp
Re: uCurrent accuracy - what am I missing?
« Reply #25 on: September 09, 2016, 03:13:47 am »
Oh, I'm sure that your stock is generally fine, but my particular unit definitely has issues.
I scrubbed the flux residue off the board but it made no difference.  Then I desoldered R9 and measured it completely out of circuit - 9.70R.  It is unambiguously busted.  I'm perfectly willing to entertain the idea that I caused it to happen through unintentional abuse, but I don't know what that abuse might have been.  It looks perfectly fine under a microscope.
Anyway, I sorted through a whole bunch of 5% 10R 0805 resistors until I found one that happened to measure exactly 10.0 ohms, soldered that one into the R9 place, and now I get 0.9992 V out for the 1.000 mA DMMCheck current source, which probably means it's just about perfect considering that the UT61E seems to read DCV about 1 mV low anyway.  I'm sure the tempco on this replacement resistor isn't great but it'll do for my purposes, I guess.
Offline int2str
« Reply #26 on: October 13, 2016, 10:50:03 pm »
Took a while to get to this.
De-soldered R9 and sure enough it was off.
Bought a replacement from Digikey and now it reads much closer on the mA scale.
Still have to replace the other resistors next.
Too bad it came this way :(
Offline JDW
  • Country: jp
« Reply #27 on: March 29, 2017, 10:17:12 am »
I thought all uCurrent's were 100% QC tested prior to shipping.  Or was that done only on the original, non-Gold edition?
