HA HA i am super happy about this program,
just added two I2C temperature sensors TMP275, Via arduino
modifyed the good example code and TC driver allready provided my HKJ (see homepage links)
with the power of average I can get even more resolution, from a temperaure sensor,
its native resolution is 0.0625C wich is quite allright, but its jumps are very nice and PWM alike, see the attached picture,
this means with average added on top of this, you can get the values in between the native steps :-)
i need this, for my temperature controlled voltage refferance , so i can reveal how well or bad, the temperature regulation performs.
side note : the two sensors are hand soldered to wires, and not calibrated, the values you see here, are directly what the chips say,
my plan is to add 8 and make a nice temperature monitor unit.
Temperature Measurement is one of the most important things to get into your data set
almost no matter what kinds of science recording you are doing.
PPS : incase any of you want to play along, with Test Controller and Arduino, I found a problem with reset, lock up, and program not running
when a new connection to TC is made, HKJ and I are on it, i plan to dig more into it during the next weeks, until then, if you see this, just short reset to +5
while you hit the reconnect button in TC and all will be fine.
