V2.61 is up
KungFuJosh has added a lot of devices to this release, other has also added devices and as there is some bug fixes.
Added: PENDULUM CNT-90, PENDULUM CNT-90XL, PENDULUM CNT-91, TEKTRONIX FCA3000, TEKTRONIX FCA3100, FLUKE PM6690 Frequency & Time Interval Analyzer (Thanks KungFuJosh)
Added: Agilent 53181A, Agilent 53131A, Agilent 53132A Universal Frequency Counter (Thanks KungFuJosh)
Fixed: The right-click function to insert column names will now use the correct var name when column and var name is different.
Added: Owon SPM3051, Owon SPM6053, OWON,SPM3103 DMM + PS, note: control both, only log DMM (Thanks TishSerg)
Added: Digitech QM1462 DMM, may also support a couple of other meters (Thanks DeanA)
Fixed: Option "Fast charting" did not enable/disable consistently.
Fixed: ParamSweeper, the "log" checkmark required support for read-back, now it will instead use the write value when that is not possible
Added: R&S SMIQ02B, R&S SMIQ02E, R&S SMIQ03B, R&S SMIQ03E, R&S SMIQ04B, R&S SMIQ06L, R&S SMIQ06B, R&S SMIQ06ATE RF generator (Thanks KungFuJosh)
Added: R&S SML01, R&S SML02, R&S SML03, R&S SMV03 RF generator (Thanks KungFuJosh)
Added: Keysight V3500A RF power meter (Thanks KungFuJosh)
Added: Text to separator control and one extra line type (Sinus)
Fixed: GPIB serial interface did not use the initialisation delay
Added: Tektronix DMM4040, DMM4050 Bench DMM's (Thanks Gertjan)
Changed: Save file works better with low values.
Added: ACT/6000, Greenlee DM-210A DMM they are similar to BM250 series (Thanks markm6164)
Added: Owon XDM1041 (Thanks Elektroarzt)
Added: Mustool ET4410 LCR meter (Thanks Furna)
