Yes, logging will also change from dBm to V or vice versa.. (On both generators it is a mode change)
But I don't think this a a problem. One will work either with dBm or in Volt. (just what is appropriate for the current measurement)
So the generator stays in the current used amplitude unit.
The issue is if the user uses the function and the column change unit, that means it will list values with two different units in the same column at the same time.
My thinking is that if one, for example, is working in Volt, logging will be done in Volts.
Using the #interface commands to set/get Volts will keep the mode in Volt. So no problem.
Only when using the dBm #interface commands, the mode will change. But who will use/need the dBm commands when working in Volts?
But maybe I am missing something?
If you are not happy with it, I will leave it out.
Regards, Gertjan.
