Author Topic: Program that can log from many multimeters.  (Read 497288 times)
Offline Pukker
« Reply #1375 on: January 07, 2021, 07:40:06 pm »
I am struggling with my Riden RD6012.
Debug shows the following message:
;; Start thread for: COM3 - Riden RD6012
;; COM3: Set params: 9600
;; : Tx <holding? 0x00>
;; COM3: Tx: 01 03 00 00 00 01 84 0A
;; COM3: Rx: 01 03 02 EA D9 36 BE
;; COM3: **Device do not match** <60121>
;; USB Serial (COM3) Device Riden,Riden RD6012 do not match: **Device do not match** <60121>
;; COM3: Close
;; Stopping thread for: COM3 - Riden RD6012
;; COM3: Close
Set baudrate to 9600 etc.
BTW. logging with DL24 electronic load works fine.
Can anyone see what is going wrong.
Thanks in advance.
Edit: Sorry for asking, replaced in RD60XX.txt:
#replacetext RD60xx 60122 with #replacetext RD60xx 60121
Now it works. Happy me.
Thanks HKJ and Mike Lud for the software and RD60XX file.
« Last Edit: January 07, 2021, 07:58:50 pm by Pukker »
Offline MikeLud
« Reply #1376 on: January 07, 2021, 08:25:19 pm »
HKJ,
I updated the file
Offline HKJTopic starter
    • Tests
« Reply #1377 on: January 07, 2021, 08:34:47 pm »
I have one question: Is there one or two ID's for the 6012 supply?, i.e. did Riden change the ID at some time?
I.e. if anybody reading here has a RD6012 working with the current software, please say.
Offline MikeLud
« Reply #1378 on: January 07, 2021, 08:37:37 pm »
HKJ,
I am not sure, I only have a 6006.
Offline Pukker
« Reply #1379 on: January 08, 2021, 08:26:13 am »
HKJ,
I also don't know, I am using the modified firmware by Unisoft (which is great),
could that anything have to do with that? I don't know.
Also saw that there was an error in current settings.
#scpiCmd ISet holding 0x09 (value) *1000
#scpiCmd ISet? holding? 0x09 /1000
must be:
maybe more to do, don't know yet, will experiment later,
I have to be more involved with testcontroller first.
Maybe the problem is because the 6006 measures current with 3 digits and the
6012 with two digits. 3.000A vs 03.00A
« Last Edit: January 08, 2021, 05:45:35 pm by Pukker »
Offline joxelito
« Reply #1380 on: January 15, 2021, 09:29:02 pm »
Hi!
Thanks for this great program
I am having issues with BMM AimTTi1908P multimeter with socket connection
I have written a device for this bench multimeter, it works ok but on logs i get occasional lost samples read as 0.
I have tested network, switches, cables, all is ok. On error tested netstat -an on PC with W10, but no problem connection appears as active.
Increasing ;#readingDelay does not make difference. Tested from 2 to 10
On errors some values appear on command window.
Attached is a log chart, also the commad window, on some errors I changed de PS value manually to check if system was locked. I set up an alarm and changed voltage as soon as I heard the sound.
Deviced file is attached too
« Last Edit: January 15, 2021, 09:33:22 pm by joxelito »
Offline faraday
    • ielektro.net
« Reply #1381 on: January 15, 2021, 10:34:38 pm »
I really like this APP is simple and powerful.
    • Tests
« Reply #1382 on: January 16, 2021, 03:36:35 pm »
Did you try without the semicolon in front?
Offline joxelito
« Reply #1383 on: January 18, 2021, 09:09:32 pm »
Oooops   :palm: I forgot to uncomment it
Now, after testing again with 10 seconds al 3 seconds sampling period and all looks ok
Next test will be 10 seconds an 1 sample per second
I have written another device for the Tenma DC Load, the Farnell EU versiĆ³n of the famous Koral KEL103
Some minor changes are need on the *IDN? command with respect to de KEL103 Device
« Last Edit: January 20, 2021, 09:20:24 pm by joxelito »
The following users thanked this post: faraday
Offline PaWill68
  • Country: ru
« Reply #1384 on: January 20, 2021, 12:09:40 pm »
Greetings to all.
HKJ, I have an ET5410 electronic load. SCPI control. I can fully control the instrument interface. I had some difficulties in drawing up the menu. Is it possible to make the behavior of "multi Battery_ *" look like the picture. Manage "radio Discharge_Mode"?
I have many questions, I will ask them later.
#cmdSetup radio Discharge_Mode BATTERY
:read: BATT:MODE?
:write: BATT:MODE #;[300];CH:MODE BATT;[300]
:update: Discharge_Mode; ; CCCV99
:tip: Set the discharge mode of the battery test
:string:
CC CC
CR CR
:updatemodechange:
#cmdSetup multi Battery_I BATTERY
:read: CURR:BCC1?;CURR:BCC2?;CURR:BCC3?
:readmath: value.replace("R","")
:write: CURR:BCC1 #;[300];CURR:BCC2 #;[300];CURR:BCC3 #;[300]
:update: Battery_I;Discharge_Mode
:tip: Set the constant current current value
Number 1_ I 0 42
Number 2_ I 0 42
Number 3_ I 0 42
:enable: 1
#cmdSetup multi Battery_V BATTERY
:read: VOLT:BCC1?;VOLT:BCC2?;VOLT:BCC3?
:write: VOLT:BCC1 #;[300];VOLT:BCC2 #;[300];VOLT:BCC3 #;[300]
:update: Battery_V
:tip: Set the constant current cut-off voltage value
Number 1_ V 0 155
Number 2_ V 0 155
Number 3_ V 0 155
:enable: 1
#cmdSetup multi Battery_R BATTERY
:read: RESI:BCR?;VOLT:BCR?
:write: RESI:BCR #;[300];VOLT:BCR #;[300]
:update: Battery_R
:tip: Set the constant resistance cut-off voltage value of battery test mode
Number R_ Om 0 500
Number V_ V 0 155
:enable: 0
    • Tests
« Reply #1385 on: January 20, 2021, 05:52:07 pm »
The radio button creates a variable you can test on:
:enable:  BATTERY.Discharge_Mode=="CC"
Remember that programming is case sensitive.
The following users thanked this post: PaWill68
Offline PaWill68
  • Country: ru
« Reply #1386 on: January 20, 2021, 06:52:33 pm »
HKJ, thanks, it helped.
Tell me, is there an event that handles a click on bookmarks?
    • Tests
« Reply #1387 on: January 20, 2021, 07:18:51 pm »
I am not sure what you mean by bookmarks.
Mostly you cannot customize the user interface, but there are exceptions:
  • The popup menu in the log window, can launch scripts that can do nearly everything. These scripts can be generated automatic for some functions.
  • The readouts do also support some customizations.
  • GridPanel, it can be customized in many ways and handle a lot of stuff in TC. You can save multiple different GridPanels, but only one  can be open at a time.
Offline PaWill68
  • Country: ru
« Reply #1388 on: January 20, 2021, 07:53:05 pm »
I would like to make sure that when navigating through the tabs, the interface on the device changes.
    • Tests
« Reply #1389 on: January 20, 2021, 07:59:51 pm »
Tabs don't work that way, but you can use "Selector".
Check bench meters (Like Keysight 344xx) to see it used.
Offline PaWill68
  • Country: ru
« Reply #1390 on: January 20, 2021, 08:14:48 pm »
I need to do
:write: CH:MODE **where ** are interface switching commands, for example
:write: CH:MODE {CC|CV|CP|CR|CCCV|CRCV|TRAN|LIST|SCAN|SHOR|BATT|LED}the display switches.
I can do it in "Mode" with the command
#cmdMode 11.Battery: write: CH:MODE BATT; [300]
#cmdMode 12.LED: write: CH:MODE LED; [300]
    • Tests
« Reply #1391 on: January 21, 2021, 09:05:24 am »
#cmdMode 12.LED: write: CH:MODE LED; [300][/code]
Check a bench DMM definition and the documentation for how to specify a #cmdMode
It is something like this:
#cmdMode VDC VOLT
abort
[500]
*cls
And you can add the VDC as fourth parameter to #value commands, this will control enabled columns.
Offline PaWill68
  • Country: ru
« Reply #1392 on: January 21, 2021, 09:07:24 pm »
Fixed the error and specified the parameter.
#askMode CH:MODE?Got an answer
Starting
;; Start thread for: COM10 - East Tester ET5410
;; COM10: Set params: 115200
;; : Tx <*IDN?>
;; COM10: Tx: <*IDN?. |..> 2A 49 44 4E 3F 0A 20 7C 2E 0A
;; COM10: Rx: <ET5410 09411912032 V1.02.1901.023 V1.10.1810.018> 45 54 35 34 31
30 20 30 39 34 31 31 39 31 32 30 33 32 20 56 31 2E 30 32 2E 31 39 30 31 2E 30 32
 33 20 56 31 2E 31 30 2E 31 38 31 30 2E 30 31 38
;; COM10: Tx <*TRG>
;; COM10: Tx: <*TRG. |..> 2A 54 52 47 0A 20 7C 2E 0A
;; Found East Tester ET5410 on CP2102 USB to UART Bridge Controller (COM10) sn:
9411912032
;; ET5410: Tx <CH:MODE?>
;; COM10: Tx: <CH:MODE?. |..> 43 48 3A 4D 4F 44 45 3F 0A 20 7C 2E 0A
;; COM10: Rx: <CC> 43 43
;; ET5410: Rx <CC>
In the #cmdMode section
#cmdMode 01.CC CC CH:MODE CC;
#cmdMode 02.CV CV CH:MODE CV;
This option works and switches modes.
;; ET5410: Tx <CH:MODE CV>
;; COM10: Tx: <CH:MODE CV. |..> 43 48 3A 4D 4F 44 45 20 43 56 0A 20 7C 2E 0A
But then he writes that the CC mode, although in fact CV.
;; ET5410: Rx <CC>
CH:MODE?
;; COM10: Rx: <CV> 43 56
;; ET5410: Rx <CV>
;; CV
For some reason, after switching, it shows the previous mode.
Sorry for my English. I use google translator
« Last Edit: January 21, 2021, 09:22:51 pm by PaWill68 »
    • Tests
« Reply #1393 on: January 22, 2021, 10:08:45 am »
Try writing it the way I do (i.e. multi line), if that works please post again and I will look for a bug in the code.
Setup pages do not automatic update after a mode change, you have to use a ":updatemodechange:" tag.
It could also be because the load needs some time to switch mode, i.e. you need more delay before asking for mode.
Offline PaWill68
  • Country: ru
« Reply #1394 on: January 22, 2021, 11:16:01 am »
That's right?
abort
[500]
*cls
abort
[500]
*cls
answer
Starting
;; : Tx <*IDN?>
9411912032
;; ET5410: Rx <CV>
;; ET5410: Tx <CH:MODE CC>
;; COM10: Tx: <CH:MODE CC. |..> 43 48 3A 4D 4F 44 45 20 43 43 0A 20 7C 2E 0A
;; ET5410: Tx <abort>
;; COM10: Tx: <abort. |..> 61 62 6F 72 74 0A 20 7C 2E 0A
;; ET5410: Delay: 500ms
;; ET5410: Tx <*cls>
;; COM10: Tx: <*cls. |..> 2A 63 6C 73 0A 20 7C 2E 0A
;; ET5410: Rx <CC>
now the answer to the command "CH:MODE?" right
    • Tests
« Reply #1395 on: January 22, 2021, 11:35:15 am »
That's right?
#cmdMode 01.CC CC
CH:MODE CC
[500]
#cmdMode 02.CV CV
CH:MODE CV
[500]
Try without the [500] and also with some shorter time.
Offline PaWill68
  • Country: ru
« Reply #1396 on: January 22, 2021, 12:05:33 pm »
The error appears if the delay is less than [200]
    • Tests
« Reply #1397 on: January 22, 2021, 01:07:20 pm »
This means the load need 0.2 second to change mode. This time may not be the same between all the modes and you will want to use the slowest change time.
Offline PaWill68
  • Country: ru
« Reply #1398 on: January 22, 2021, 03:58:25 pm »
I think I understood the ideology of the Mode button and the Selector. But I got new problems. I am using Selector and multi does not fill when switching Mode. If multi is omitted below selector, then they start working. What could be the mistake?
    • Tests
« Reply #1399 on: January 22, 2021, 04:04:43 pm »
That sounds like a bug in my code, I will have to look at it, probably tomorrow.
You might be able to use numberDual instead for some of the cases.
« Last Edit: January 22, 2021, 04:08:14 pm by HKJ »
