V1.65 is up
It includes some internal improvements and download of data from a couple of multimeters.
Fixed: Automatic column changing with mode change on multimeter did not always work.
Update: ET5410 more advanced definition by PaWill68 (Thanks)
Added: holdingBytes? for modbus protocol, it returns a bytes data type and must be processed with :readmath:
Fixed: Kunkin KP184 now works in V4 and newer, thanks to help from some users.
Added: Keysight U125xA now support downloading of log
Added: Keysight U128xA now support downloading of log
Added: Keysight 344xxA now support downloading of data from internal flash memory
Added: Other button, this will be visible for devices where download of screenshots or data is supported.
Added: deviceReadBytes to read a binary IEEE block from a SCPI device.
Added: floatBytes, doubleBytes to control casting of float/double to bytes.
Added: binConvString that converts a bytes type to a text string.
Added: binConvFloat that convert a string/bytes/int/long to float/double if it contains the correct bits.
Added: binConv supports bytes data type
Added: subbytes function similar to substring but for bytes datatype
Added: bytes as new data type, this is only used for handling communication and not for normal math.
The download of data means that there will sometimes be an extra device button called "Other"
When clicked it will show a menu, the contents of this menu will depend on the device. Data can be downloaded as either text of into in the table (That will be cleared first).
