I would like to report an issue: I'm running TC 2.91 on linux mint (I haven't tried on windows yet):
All my devices are connected via serial (USB and bluetooth). If I loose connection (cable disconnected or bad bluetooth signal) while running a log, or after stopping it, the program start using 100% of one core of my CPU.
To stop the CPU usage I have to reconnect the instrument or disable it and click reconnect.
Is it normal?
*I'm using two custom config files, but one of the two is a slightly modified keithley 2000 device script so that it works with K2700/2790 so it shouldn't be an issue.
______________________________________________________
On an other note I have some "suggestion"/questions for the UI. (But maybe I'm using it wrong).
-While log is running the reconnect button is disabled, but I can modify the list of devices (enable, change ports...). Often I forget that a scan is running and start messing with the connections and then see that the reconnect button is disabled.
Shouldn't the table be disabled too?
The reconnect button is a bit hidden down there and far from the tabs (requiring lots of mouse travel), putting it on top maybe would make it more visible and easier to click.
-An other cool addiction for the load page would be showing the device ID in the table. I have many serial devices that won't remember the serial port numbering (the serial chip has no id so the pc assigns random port...) or often I forget it.
By clicking a "ask IDN" button the program would scan all enabled devices asking the respective ID command (even for non SCPI instruments (#scpiCmd *idn? txrx? I?)).
-An other issue is that, if you are not in the commands page, you can't see if the log is enabled and running.
Would be nice to have some sort of indicator visible in all pages and maybe an indicator that blinks every time that a new reading is completed (a bit like in some multimeters). Maybe you could add some text to the page selector label, or in the tab title (like in the image).
-When changing the setup of multiple instruments, to select them I move the mouse all left and then all right, having a device selector closer to the buttons would be nice. Without reading the instructions I couldn't understand how to change instrument (Before I used "show all setup popups").
-Could be possible to pause the log, and maybe reconnect instruments while paused? Often I have to move around stuff during a scan ruining it. It would be an incredible feature.
Thank you!
Tiziano
