I'm playing around with my upgraded Siglent 1032x testing an HP5370B. I have a Rubidium standard on the 5370B and tried bringing that into the 1032x as well. I see 2V p2p on the reference signal but it doesn't look like the 1032x is recognizing it as the output frequency is still off by 24hz, same as if I disconnect the standard. I looked around the menus, can't find any way to turn the external frequency reference on.
Ideas?
Jerry
by the way, the reference BNC on the back is labeled In/Out and there isn't a signal on it except for a 16mv, 25Mhz, peak crappy looking square wave. Looks like there is an issue with the port maybe?
OK, forget all this, I found the setting under "clock". would have named it "reference" myself! You can turn the output on, etc
Thanks anyway!
