Author Topic: Protocol decode wishlist  (Read 18172 times)
Offline MrW0lf
  • Country: ee
    • lab!fyi
Re: Protocol decode wishlist
« Reply #25 on: April 13, 2017, 07:29:51 pm »
Mine does voltage stats per packet, but not inline.
Offline JPortici
« Reply #26 on: April 26, 2017, 07:13:04 am »
crazy idea: PWM decoder. each packet is a PWM pulse and the value is the duty cycles.
I've seen it only in a recent product (the patchblocks mini synths: two blocks communicate with each other with a digital signal that is nothing but a PWM + input capture)
i recall that PWM was also used in older automotive diagnostic standard?
I can sort of do this with the picoscope, plotting a math trace with duty cycle as an expression
Offline MrW0lf
  • Country: ee
    • lab!fyi
« Reply #27 on: April 26, 2017, 07:50:06 am »
How many discrete values of PWM duty?
Online nctnico
« Reply #28 on: April 26, 2017, 03:09:41 pm »
Another way of dealing with PWM is to use input filtering.
Offline JPortici
« Reply #29 on: April 26, 2017, 05:25:21 pm »
no, you don't understand: the goal is not to reproduce an analog waveform but to send data, each pulse is a word.
Offline Daniel Bogdanoff
  • ALL THE SCOPES!
« Reply #30 on: April 26, 2017, 05:35:59 pm »
What I would like to see is JESD204, QSPI, I2S, and NFC, with non intrusive probe kit.
I think Keysight have a solution for NFC.
We do have NFC, I2S, and Manchester recently added.
Test and Measurement!
Online mikeselectricstuff
    • Mike's Electric Stuff
« Reply #31 on: April 26, 2017, 09:27:17 pm »
Could you maybe do this with measurement trend on a pulse-width or duty-cycle measurement
Day Job: Mostly LEDs
Offline mubes
  • Do Not Boil
« Reply #32 on: April 26, 2017, 10:22:16 pm »
Personally, irrespective of protocol, what i would like to be able to do is to live stream the decoded data down to a host pc for further processing. That way, I get the triggering, channel and sensitivity flexibility of the scope coupled with the data chewing capabilities of the pc. It's possible that this can already be done (i haven't looked in any detail, i have other tools that are usually good enough) but it's certainly not a use case I'm comfortable using a scope for.
Offline bson
« Reply #33 on: April 28, 2017, 12:59:21 am »
Even better, allow it to use a network volume in lieu of the internal storage or USB drive.  My WaveSurfer will happily save decoded data, screenshots, trace history, notebooks, and anything else straight to my Synology DS1515+ NAS.
Online nctnico
« Reply #34 on: April 28, 2017, 10:06:54 am »
The newer GW Instek oscilloscopes can do that too (GDS2000E / MSO2000E, not sure about the GDS1000B series)
Offline gardner
« Reply #35 on: April 28, 2017, 07:42:39 pm »
Wiegand anyone?
10BASE-T or 100BASE-T?
--- Gardner
Offline colorado.rob
« Reply #36 on: May 16, 2017, 02:48:57 am »
I just found this thread.  I'm in the market for a mixed signal o-scope and one of the key things I need is USB decode. The last few times I've pulled my Saleae LA out, it was for this.  Such a common protocol, I'm surprised it's not more common.
Does anyone have a list of MS scopes that support USB decode?
