I found a Fluke 8840A at my local electronic surplus for $75. Not sure if its working, but do you think it is worth the price? Also how difficult would it be to repair if it does not work? Should I pick it up without testing it. I can go at lunch and get it but I wanted to know what the forum thinks.
Thanks for your inputs.
The 8840A has 2 options, AC and GPIB. For AC, you can't trust the checkmark on the back. If it has AC and works, that's an OK price, nothing special. If it has AC and GPIB, it's good.
Watch out for aged VFDs (dim and stripy)... replacements are expensive.
If the CPU is bad, it's really hard to find a replacement.
Other problems can be fixed.
Don't buy without a quick test.
