I've seen catalogues price it at $180 USD? That's 10% of the cost of the scope itself.
that probably only for renting a space in their calibration lab, Keysight et al are known for their "fabulous" after sale service charge. you are talking 10% of "used" price. its new price is like 8K i guess, so expect something like AUD800. but thats just a wild guess. i recently bought an used spectrum analyzer, its calibration cost is 150% from what i paid for the unit. now that should start to worry you
Since you seem to work in this space, and you're based in NZ, what is your estimation of how much this will cost me (I'm based in AUS)?
If you have to ask, you can't afford it.
You need to understand the difference between "calibration" and "adjustment". Roughly speaking calibration means comparing to specification and noting where in/out of spec, whereas adjustment means twiddling it until it is in spec.
Thanks for the clarification. If it's really that expensive, then I'll just have to make do without it. Anyway, as the guys above said, as long as it passes the self-tests and has no obvious problems, I'm guessing it will be fine for my work.
I'm curious to learn about how such a device is maintained to function well. These are expensive devices in the first place, so I'm guessing that you guys don't go around paying for calibration in addition to that, so what do you do to calibrate it when you notice that there's problem? Given the amount of time people put into personally repairing their expensive scopes, surely there's something you guys do for calibration too?
I'm keen to start studying some oscilloscope-specific material (in addition to the other electronics material I'm studying), so if you guys have any textbook suggestions, I'd appreciate it. Something less technical to start off would probably be best, but then I'd like to jump into some technical material that will really give me a deep understanding of the device, so those recommendations are also appreciated.
