Author Topic: Purpose of D1 and D2  (Read 1100 times)
Offline abdulbadiiTopic starter
« on: September 30, 2021, 03:45:07 am »
Would anyone please help out explain or show what is the purpose of D1 and D2 in circuit:
« Last Edit: September 30, 2021, 03:46:41 am by abdulbadii »
Offline bob91343
Re: Purpose of D1 and D2
« Reply #1 on: September 30, 2021, 04:52:28 am »
They clip the wave to about 0.7V peak, or 1.5V p-p.
Offline TurboTom
« Reply #2 on: September 30, 2021, 06:49:43 am »
They are just for ESD protection and to safely discharge the DUT if someone attaches a charged cap to the tester. Voltage across the capacitor is unidirectional and very low (0.1V max). It's a very simple but still interesting instrument. In a practical setup, one of the voltage dividers (probably ideally R9/R10) should be adjustable to zero out the reading while no DUT is attached. The device will only work for (comparably) large capacitors (electrolytics) since it doesn't have a phase-sensitive rectifier and requires Zc to be much smaller than ESR to produce an accurate result.
« Last Edit: September 30, 2021, 06:59:22 am by TurboTom »
The following users thanked this post: abdulbadii
