Relative Cheap LCR Smart tweezers are coming out of China in bulk these months.
Specs.
0. Measure voltage (up to 16V)
1. Measurement frequency: 100Hz/120Hz/1kHz/10kHz/100kHz
2. Measurement voltage: 0.1Vrms, 0.3Vrms, 0.6Vrms
3. Measurement type: resistance, capacitance, inductance, voltage, on-off, diode
4. Resistance range: 1Ω~10MΩ
5. Capacitance range: 1pF~22mF
6. Inductance range: 1uH~22H
7. Voltage range: ±0.1V~±16V
8. Basic accuracy: 0.5%±2
9. Use time: 7 hours continuously
10. Battery capacity: 500mAh
11. Charging voltage: DC 5V
12. Charging current: 200mA
13. Screen size: 1.47inch, 172*320 resolution
Shell material: ABS+metal
Product size: about 138.00x22.00x15.00mm
Product size: 5.43x0.87x0.59inch
[Promo sales text]
* 1. Advanced Measurement Capabilities: The Digital Smart Tweezer supports intelligent detection and measurement of resistance, capacitance, inductance, voltage,
continuity, and diodes. It also measures ESR/EPR and Q/D values, providing comprehensive testing solutions.
* 2. Portable Lightweight Design: The LCR SMD ESR Tester features a convenient tweezer design, measuring 138x22mm and weighing only 40g. Its compact size makes it
perfect for on-the-go use or fieldwork where space and weight are crucial.
* 3. High-Resolution Display: Equipped with a full-view 1.47-inch color IPS screen, the Resistance Capacitance Inductance Continuity Diode Test tool provides clear and
detailed readings of L, C, R, D, Q, and RS. The intuitive interface enhances workflow efficiency.
* 4. Smart Auto-Range Function: The Auto Multimeter Tools include a smart auto-range feature, allowing the device to automatically select the appropriate measurement
range for each task. This simplifies the process, reduces setup time, and ensures optimal accuracy.
* 5. Versatile LCR Meter Tweezer: The LCR Meter Tweezer is ideal for a wide range of applications, offering precise and efficient measurements in a compact form factor,
making it an essential tool for professionals and hobbyists alike.
![QPLink LCR 1S Smart Tweezer [100Hz - 120Hz - 1kHz - 10kHz - 100kHz] ≈ 50$](https://www.eevblog.com/forum/index.php?action=dlattach;topic=442317.0;attach=2401307;image)
![QPLink LCR 1S Smart Tweezer [100Hz - 120Hz - 1kHz - 10kHz - 100kHz] ≈ 50$](https://www.eevblog.com/forum/index.php?action=dlattach;topic=442317.0;attach=2401303;image)
