After undoing the birds nest and soldering several cut traces. I think I did it correctly. though not sure if the cathode of zener diode next to R53 is connected to it or not. I connected it. Ran out of patience, crossed my fingers, plugged the unit in and turned it on. No sparks but, It was still not making any measurement. it was stuck on 4.232 M ohm. it was stuck on that number in every range but decimal was moving. before undoing the birds nest the unit was stuck on 5.5xx M ohm, That's when I decided to get the short finder for dummies out, the thermal camera. I was not looking for a short but just wanted to see what is on. And yes, there was a short there. But, unfortunately, I did not take a before thermal picture. So, I don't know if removing the birds nest and connecting R53 to the cathode of the zener next to it caused this issue or was it this way before. If anyone has picture of the back side of the board I would appreciate it if you could send some clear pictures of the backside of the board of quadtech 1880. thanks.
Bob
