I didn't think myself that inrush should be a problem with LD400P. But, I just don't know it for a fact.
The way I analyzed it was to look at the specs for the TTi to see how fast it can change levels.
As a general rule of thumb, the faster the change the greater the overshoot and the higher the spike produced, and also the greater the intensity of the burst of electromagnetic radiation emitted, even if for a short time. That's because, at the most fundamental level, Maxwell's equations tell us that the magnetic field created is proportional to the time-rate-of change of the electric field, and visa versa,
curl B = dE/dt, curl E = - dB/dt, etc..
So, anytime you change electrical parameters "more quickly", you've generally got to deal with higher spikes and more
intense bursts of EM.
The KIKUSUI is in a class of it's own, boasting a whopping 50A/us for PLZ-4W and 60A/us on newer PLZ-5W series. Whenever you have circuits designed for that kind of responsiveness, you've got to expect spikes when switching on these circuits, or even switching levels while on, in normal operating mode. The whole system must be designed to exhibit this fast responsiveness throughout the circuitry. That's because, in a relay race, the slowest runner determines the limit of overall speed of the team. I seriously doubt, that the KIKUSUI can do all this in a purely linear manner like the AIM-TTi. But, then again, I don't know.
Now, to compare, I looked at what I could find in the LD400 documents to get some idea of TTi's responsiveness.
Here's some relevant specs from pg.4 of the LD400 Series manual:
Specifications
If we convert the A/s in the CC mode shown to A/us to put the numbers on the same basis
as the KIKUSUI quoted 50-60A/us values, we get:
8A range: 2.5A/s to 250A/ms =or= .0000025A/us to 0.250A/us
80A range: 25A/s to 2500A/ms =or= .000025A/us to 2.500A/us
Highest rate of change for AIM-TTi LD400 Series is 2.5A/us
Highest rate of change for Kikusui PLZ-4W Series is 50A/us
Highest rate of change for Kikusui PLZ-5W Series is 60A/us
So Kikusui is more than 20 times faster than AIM-TTi at the LD400P's fastest speed, and more than 200 times faster than LD400P on its 8A range.
The AIM-TTi LD400P is like a Tortoise on the race track, while Kikusui is the Hare.
But, there are always design tradeoffs to make when attempting to construct any kind of circuit. I'd suspect that AIM-TTi LD400P has no spikes, overshoots, etc.. to be worried about, so would be relatively safe to hook up to almost any circuit, that might have sensitive components that could be affected by such things, but wouldn't be able to keep up with some of the modern fast changing circuits out there.
While, the Kikusui might happily handle anything you throw at it, but probably wouldn't be nice to some kinds of sensitive circuit components, especially if you didn't know exactly what you were doing on each occasion. e.g. a hobbiest like me.
So, a back of the envelope quick guess, or Dave's thumb, would suggest that perhaps the LD400P should have 20 times smaller inrush peak than the KIKUSUI, or 45A/20 = 2.5A peak.
Of course, there's nothing that says the inrush is linearly related like this, but, lacking further knowledge about the design, it's a best efforts guesstimate. I'd hardly think that the inrush would be higher than the Kikusui, but who knows? It could all come down to the efficiency of the design in achieving the design goals.
But, this slow response of the LD400P vs Kikusui also supports MarkL's observation that the LD400P can't keep up with the time-changing parameters for loop response tests. The LD400P is a different type of beast, intended for low voltage and slow changing parameters, like solar cell testing, for example.
I notice that Bob Hanrahan of Texas Instruments used a Kikusui PLZ164WL in his power supply testing instructional video series. That's where I first became aware of the Kikusui. If texas instruments chose this instrument for their testing, it must meet or exceed the specifications required for such design testing. However, I can't afford such luxary equipment.
I considered the AIM-TTi LD400P, because I bought the AIM-TTi MX100TP and really like this three-channel power supply. So, I figured, let me stick with AIM-TTi and get the DC load too. It's in the price range of my limited budget.
MarkL, you mentioned that other DC Electronic Loads in the same class as LD400P were better at loop response tests. Could you elaborate a bit, what other brands and units did you comapare this AIM-TTi produt to? Are they in the same price range?
