Thanks for the advice, but I think it's safer to remove the batteries if you don't want to change the type.
Vapours are also the most treacherous, and if you let gravity do its work, you need to make sure the holes connecting to the inside of the device aren't at the top.
For me, the corrosion of the contacts cost me the most I could do: replacing the small metal pieces available for sale. However, the fumes had destroyed the tracks and contacts inside, especially the delicate ones on the contact displays. I managed to get the battery compartment working as good as new, but the device would still show strange signs of loose contacts and resets without cause, until it completely died.
Filippo
