i've hit up victor from the diyaudio forum to see if he has any of his boards available. he is getting better then -150 Db.
What circuits? I've seen link to e-b
https://www.ebay.com/itm/Low-Distortion-Audio-Range-Oscillator-1KHz-Sine-Wave-Signal-Generator-PCB-Board/262844562138, let's call it JFET-Wein, description says:
Low distortion coefficient of the sinusoidal oscillator circuit board, oscillation frequency: 1KHz, low distortion, distortion factor 0.0064% (- 124dB)
doesn't look right, in my math -120dB is 0.0001% ( or 1ppm), 0.0064% is about -84-85 dB, worse than cheapest sound card has. And NE5532 ? Common, be serious.
Or is it CdS-Wein?
http://www.redcircuits.com/Page82.htmProbably, just simplified version of
https://www.analog.com/en/design-center/evaluation-hardware-and-software/evaluation-boards-kits/dc1858a.html#eb-overviewI trust AD, performance is outstanding, but same with a price and complexity.
Though -120 only:
Table 1. Amplitude and Offset Options for DC1858A (SNR and THD Taken at f OSC = 2kHz)
Range (V) R22 (kΩ) R18 (kΩ) C11 (μF) Sine Out (V P-P ) Offset (V) SNR (dB)* THD (dB)*
0 to 2.5 14 36.5 0.47 2.25 1.25 100 –119
0.5 to 4.5 22.6 12.1 0.47 3.6 2.5 103 –121
0 to 4.096 23.2 17.4 0.47 3.7 2.048 103 –121
0 to 5 28 12.1 0.47 4.5 2.5 104 –118
±2.5 28 ∞ 0.47 4.5 0 104 –119
±5 56.2 ∞ 0.47 9 0 107 –117
±10 118 ∞ 0.1 18 0 100 –107
page 3
https://www.analog.com/media/en/dsp-documentation/evaluation-kit-manuals/dc1858af.pdfAnd most resistors precise 0.1% tolerance, they can't get -120dB with CdS even for single Tone generator using common 1% parts, and adjustable frequency doesn't go along with precision parts at all.
