The UNI-T UTG 932 or 962
Both work out the Box and have a full warrantee form Uni trend .
OEM link from
https://www.aliexpress.com/item/4000373256414.html?spm=a2g0s.9042311.0.0.2b034c4dZU1VGJ Personalty I'm not easily impressed But this UTG962 is really impressive and the spec's are correct.
Value for money .Yes .
FY 68 / has FAKE & dodge chips so upgrading does not Help .. Been there done that .
FY69 is the same animal in a different box with a software update to compensate for the Bugs and
poor PCB design etc etc.
There are over a 1000 pages on this forum on the FY66/ ++ which was the first version .
which does respond to Upgrades . maybe the main Cyclone is better and not a Fake .
I bought the FY68 about a year back . The power supply literary went up in smoke after 2 hours
of Run time . Feeltech never replied to my emails . The supplier gave me a 30% refund and said
find some one to fix it
So if you want to put your well earned money on a No guarantee that it will even work when you receive it .
Go for it .
The other similar looking AWG 's are properly rebrands as the menus and the insides look very similar.
(Clones of Clones)
If you are learning over time you will want to upgrade say your DSO as your knowledge grows
So if you learn on equipment that is good . and may last you 5 to 7 years .
You don't always need the very best scope on the market If your working in low frequents
ranges say up to 5Mhz .
Remember one rule of thumb you need a scope at least x10 bandwidth of frequency required .
Good tools will give good results .
Buy from Brand Names of Know established companies .
We all love a bargain but if the Data spec's looks better than High end Equipment
Its a P.O.S
BTW update . UNI Trend has patent A square wave design that's on there new model
that goes to 70Mhz Square That would out rank a lot of competitors .
I read there write up on this looks impressive . I not sure when the release date is.
I guess it will be good $$ as well .
