The 7150 is a 5.5 digit multimeter that can display 6.5 digits by using a running average filter. I am a bit confused by the spec sheet. The two-year accuracy for dc volt with 5.5 digit is 0.01% of reading + 5 digits, and the 6.5 digit display will add 10 digits to that. Does that mean the accuracy for the 6.5 digit display is 0.01% of reading + 15 digits? 15 digits of 6.5d display is equivalent to 1.5 digits of 5.5d display. I thought averaging filter can't improve accuracy. Am I interpreting it wrong?
Yes, that would also be my interpretation. Averaging can improve accuracy if it is limited by either noise or quantization error. If you're measuring 10 uV on a range where the least significant digit is 1 uV, then you're always going to have an uncertainty of +/- 1 uV since even if the error would have only be 0.5 uV, it can not represent steps smaller than 1 uV so it will show up as 1 uV error. If the actual value is 10.4 uV, then even 0.2 uV error would push it to 10.6 uV which would be seen as going from 10 uV to 11 uV. When you add an extra digit, the error might be only 0.2 uV since the resolution is now 0.1 uV.
The other thing is noise. If that 5 digits of uncertainty is largely noise in the voltage reference, the front-end or ADC, then averaging over a longer period of time might reduce the noise (depending on the type of noise). Noise is one of the components in measurement uncertainty (together with other errors like systematic errors). Datron uses this trick in their 1080 series of multimeters that are 6.5 digit meters but through averaging (and injecting a bit of noise for reasons that are outside the scope of this post) they can get an extra digit of resolution that produces a lower uncertainty than in 6.5 digit mode.
Thank you the detailed explaination. It doesn't look like the 5 digits uncertainty is from noise, as the readings were almost constant when being hooked up to a LM399-based reference after sufficient warm-up.
I have to say the amount of accuracy improvement in this case doesn't sounds very logical to me. Imagine if I input a precise 1.000 000V to the 2V range, the meter may display a stable 1.000 05V under 5.5d, which is still within the 5.5 digit mode spec. However, no matter how much samples it takes to produce an averaged 6.5d reading, it will always be 1.000 050V, which will fail the 15 digit uncertainty for the 6.5 digit mode. In order to meet the 6.5 digit mode spec, the 5.5 digit mode must produce readings between 0.999 99V and 1.000 01V, but this will improve the 5.5 digit mode accuracy to +-1 digit. I don't think the manufacturer has any reason to underspec their products. Another possibility is that the meter's reading would jump all over between 0.999 95V and 1.000 05V with their mean sitting between 0.999 985V and 1.000 015V, but this is definitely not what I have seen with this meter.
In short, the specs for the 5.5d and the 6.5d don't seem compatible considering the stable reading of the meter. This is why I think I may misinterpreted the datasheet.
