Author Topic: Siglent SDS1102CML+ Reset lost functions  (Read 1594 times)
Offline MavMitchellTopic starter
  • Not my real name
« on: January 31, 2019, 12:25:42 am »
I have a Siglent SDS1102CML+ (actually DIGITECH QC1934) and was getting to know it. I thought it would be a good idea to use the multiple MATH key to do a factory reset(Stupid eh!).
It came back ok, but now the system status doesn't show the model number and some other functions are missing(deep memory for example).
I have Telnet access to it. Is there a config file or something I can reload to get this back?
Thanks.
Offline StillTrying
  • Country: Broken Britain
Re: Siglent SDS1102CML+ Reset lost functions
« Reply #1 on: January 31, 2019, 01:22:59 am »
Welcome to the club, I've been trying to fix that for 2 years!
Someone from Siglent did once say they were going to release FW with cfg files, but...
...and they still might not be compatible with your DIGITECH anyway.
« Last Edit: January 31, 2019, 03:00:42 am by StillTrying »
Offline StillTrying
« Reply #2 on: February 24, 2019, 08:37:53 pm »
Any luck?
Offline Muttley Snickers
  • Cursed: 679 times
« Reply #3 on: February 24, 2019, 11:59:06 pm »
It came back ok, but now the system status doesn't show the model number and some other functions are missing(deep memory for example). I have Telnet access to it. Is there a config file or something I can reload to get this back?
I almost bought one of these scopes once and was pretty sure that the Jaycar Digitech QC-1934 was a CML and not a CML+ series, the latter incorporated a higher screen resolution of 800 x 480, a LAN connection along with a different firmware version, this could be an issue if you loaded the incorrect firmware version.
https://www.siglent.eu/siglent-sds1102cml-plus.html
https://www.siglent.eu/sds1102cml-100mhz.html
https://www.siglent.eu/Downloads
« Last Edit: February 25, 2019, 02:59:39 am by Muttley Snickers »
Offline StillTrying
« Reply #4 on: February 25, 2019, 09:58:00 am »
You're right, according to this ad the QC-1934 is not a +, but nothing would surprise me, the confusion caused to sites and sellers by the + is nearly unlimited.
https://www.jaycar.com.au/7-screen-100mhz-dual-channel-dso/p/QC1934
