Author Topic: Racal Dana 1998 blown fuse in BNC connector  (Read 1863 times)
Offline PA3BBVTopic starter
« on: April 17, 2024, 10:20:50 pm »
Hi All,
I own a Racal Dana 1998. The fus in the BNC connector from input B is blown. Cannot find a replacement on internet, The subscription on the fuse is: F 1/8A
Is seems to be a keramic fuse with transparant isolation. The diameter is 2,08 mm and the length  about 7 mm
Is somebody having a partnumber or an adres where I can order a fuse? see attachment
Thank you all!
Regards, Leo
Online Jeff eelcr
Re: Racal Dana 1998 blown fuse in BNC connector
« Reply #1 on: April 17, 2024, 11:35:07 pm »
I do not know your area but Little Fuse is the manufacturer.
Not at work so looking up part number is out for now also.
Jeff
Online BrokenYugo
« Reply #2 on: April 17, 2024, 11:54:24 pm »
Any sign of who made the fuse holder?
The following users thanked this post: PA3BBV
Offline GLouie
« Reply #3 on: April 18, 2024, 12:44:00 am »
I think that is an old version of the Littelfuse Picofuse. New ones look like axial resistors.
They do come in fast and slow versions, and I can't help you on who stocks them.
https://www.littelfuse.com/industries/consumer-electronics/fuses/pico-fuses.aspx
Offline GLouie
« Reply #5 on: April 18, 2024, 06:05:53 am »
Unfortunately, the above not stocked by Mouser in UK or USA, and minimum order of 5000pc. But Digikey Netherlands claims to have these in stock:
https://www.digikey.nl/nl/products/detail/littelfuse-inc/0253-125M/553089?s=N4IgTCBcDaIAxgKwGYB0BGJBZEBdAvkA
but I don't know if the 125v rating is correct, Schurter also makes a substitute,
https://www.digikey.nl/nl/products/detail/schurter-inc/7010-6310-13/1731116
« Last Edit: April 18, 2024, 06:18:17 am by GLouie »
« Reply #6 on: April 18, 2024, 02:46:57 pm »
Thank You all for you sugggestions.
The fuse is in an BNC connector. the space in the connector is 2.4 mm. I ordered an Littlefuse from 2,6 mm en gonna try to drill the space up 0,3 mm. I have ordered fuses and keep you informed.
Offline hfleming
  • Country: no
« Reply #7 on: April 18, 2024, 03:07:31 pm »
Yes, those fuses are called ‘pico-fuses’. They are still widely available, used to protect RF stuff on their inputs.
Offline GLouie
« Reply #8 on: April 18, 2024, 09:27:36 pm »
The Schurter version claims 2.36mm dia.
Offline coppercone2
« Reply #9 on: April 18, 2024, 10:50:48 pm »
its just clear heat shrink to prevent t he glass from dispersing if the fuse breaks nasty I think.
you can get teflon heat shrink (most rugged) but it might be hard to shrink on a fuse with out damaging it (high temp required)
Picofuses come from everything, I like the versions that look like 1/4 watt resistors (green)
Offline TERRA Operative
  • Country: jp
  • Voider of warranties
    • Near Far Media Youtube
« Reply #10 on: April 19, 2024, 10:41:30 am »
HP 5335A counter uses a similar fuse-in-BNC setup on the 3GHz input option. I used the pico-fuses and it was a peefect fit.
« Reply #11 on: April 19, 2024, 09:03:57 pm »
Hi All,
Today, I have received tge pico-fuses, they fit in the connector and all is working fine again. Thank you all for the support!
The following users thanked this post: Andy Watson, TERRA Operative, GLouie
Offline BreakingOhmsLaw
  • Certified solder fume addict
« Reply #12 on: May 02, 2024, 05:40:18 pm »
Don't order the military version, it's 10x more expensive.
Digikey PN F7123CT-ND will do.
