I have an old Coline M20 'scope probe (IIRC 350MHz). It's fitted with a multiplier readout pin and resistor. The problem it would seem that the resistor is the correct value for 100x (6.75k) not for 10x even though the probe is a 10x probe.
Here's a piccie of the 'scope end of the probe after I disconnected it from the cable:
How the heck do I get in there to replace the resistor without destroying it? I'm sure it is possible, but I can't work it out!
Thanks
