to bean_dip
Good time of day.
Please tell me, in the 8300S version, in the mode with three outputs, whether it is possible TO immediately get a PWM modulated by these sinuses(20-400)Hz on three outputs. This is necessary for me to control the drivers of the three phase experimental inverter, directly from the generator, bypassing unnecessary conversion in the PWM controller.
P.S. As I understand, You are the only owner of FY8300S in this topic. Do you plan to run tests for the presence, and level of the jitter, and consider, and test its internal power supply? This will put an end to the question - what is the difference between 8300 and 6900, whether only three outputs, or they have made corrections to the problems known to many that I described above.
P.P.S. Sorry, I was inattentive. You have version 8300, without the letter "S". Therefore, the first part of the question is removed.
