Author Topic: 121GW App Testing  (Read 17149 times)
Offline Seppy
  • Curious
121GW App Testing
« on: June 08, 2018, 05:21:16 am »
Seeking testers for the iphone application sign up here:
https://goo.gl/forms/rkZiS3Jh3HJpmblC3
Please use your apple app store email address as I suspect it will make things easier.
Please take screen shots, even if there isn't a problem we don't have enough screen sizes in the office to submit to the App store.
We need screen shots specifically from an iPad and 5.5" iphones, we currently don't have any of these devices.
« Last Edit: June 08, 2018, 07:43:50 am by Seppy »
The following users thanked this post: fanOfeeDIY
Offline bicycleguy
Re: Re: EEVBlog 121GW Discussion thread
« Reply #1 on: June 09, 2018, 12:19:25 am »
@Seppy,
backer 1443
Well, I have an iPad and a 4.7" iPhone, and have written a few apps including the core and plotting part of an i121GW app.  Unfortunately, I don't have a meter to test with.  Will the screen shots you want require a connection?
I'd like to try it anyway.
« Last Edit: June 09, 2018, 12:25:09 am by bicycleguy »
Offline JonM
« Reply #2 on: June 12, 2018, 02:11:20 am »
I installed the app and did a very quick test logging temperature for a few minutes and then mailed the data to myself. It looks good so far. I would like to have the start Date and Time set in the file header. Maybe there is an option for that, I have not done any exploration...
Offline Seppy
  • Curious
« Reply #3 on: June 12, 2018, 04:15:43 am »
There isn't currently an option for that, I'll add it in, I don't want to do a full time stamp for each item though as it makes the data less importable.
I can however change the default filename to the following, how does that sound (it would also be the default email title):
"Log DD-MM-YY, HH-MM-ss.csv"
Edit: for sortablility the following format was selected, what do people think?
"YYMMDD, HHMMss Log.csv"
P.S. Post screenshots if possible we really need them for the App store submission.
« Last Edit: June 12, 2018, 04:20:28 am by Seppy »
Offline Seppy
  • Curious
« Reply #4 on: June 12, 2018, 04:22:39 am »
@Seppy,
backer 1443
Yes the screen shots would require a connection as the connecting screen is pretty boring.
Hopefully your unit arrives soon.
Offline Brumby
« Reply #5 on: June 12, 2018, 04:32:44 am »
This ^ ^ ^ ^    :-+
Offline IanB
« Reply #6 on: June 12, 2018, 05:06:00 am »
Yes, but I'd suggest without the comma. Just "YYMMDD HHMMSS Log.csv" would be fine.
I'll try to post some, but I only got the notification today. It might take me a day or two to try it out since it's the working week.
Offline mtdoc
« Reply #7 on: June 12, 2018, 05:20:02 am »
I’m confused. You are able to log or retrieve logged data with the App?
I’ve installed it on my iPad mini. I.m getting a nice mirror of the meters display but no ability to log or retrieve logged data that I can tell. The settings and maths buttons appear essentially non-functional.
Offline IanB
« Reply #8 on: June 12, 2018, 05:39:53 am »
OK, one problem is it is insisting on iOS 11.3 or later. That's a problem for me. My iPad is running iOS 10 and I won't upgrade it since IOS 11 took away functionality that I use. I will give it a try on my phone.
Offline Seppy
  • Curious
« Reply #9 on: June 12, 2018, 05:43:16 am »
Just click save under the graph.
Settings is where you add devices.
Maths is for if you owned multiple devices, you can have two plots multiply etc.
Edit : Screenshots :)
« Last Edit: June 12, 2018, 05:53:44 am by Seppy »
Offline mtdoc
« Reply #10 on: June 12, 2018, 05:56:00 am »
Thanks, but there is no save botton under the graph on my screen. There is <settings>,  <maths> and [ 0 ] only.     This is iOS 11.4 on an iPad mini 4.
Also X and Y axis values non sensible. See attached. (Meter on DC volts with open leads).
« Last Edit: June 12, 2018, 06:04:59 am by mtdoc »
Offline Seppy
  • Curious
« Reply #11 on: June 12, 2018, 06:06:38 am »
Ah right, I need to post my tutorial video, use it in portrait ,landscape is really just for fullscreen.
I might get it to show save regardless of fullscreen or not but this would take away some screen space.
Open circuit voltages will tend to be all over the place, just the result of a quite high impedance input.
« Last Edit: June 12, 2018, 06:10:52 am by Seppy »
Offline IanB
« Reply #12 on: June 12, 2018, 06:10:37 am »
Screenshot:
Offline Seppy
  • Curious
« Reply #13 on: June 12, 2018, 06:12:25 am »
Screenshot:
Do you happen to have the unscaled version? If it won't upload, could you email it here eev.davidledger@gmail.com
PS. I might fork the beta testing to another thread soon, i'll move the posts.
Offline IanB
« Reply #14 on: June 12, 2018, 06:18:54 am »
This is the raw screen grab from the phone:
Offline mtdoc
« Reply #15 on: June 12, 2018, 06:20:06 am »
Doh, OK  of course.
So in portrait, the save and other buttons are there. But, when I push save it kicks me out of the app (whether logging or not).
Yeah, i get that but axis values Not corresponding  - maybe a function of range.?
Also FWIW, i use my iPad mini almost exclusively in landscape mode. Having all buttons available would be nice.
« Last Edit: June 12, 2018, 06:27:24 am by mtdoc »
The following users thanked this post: Seppy
Offline IanB
121GW App Testing
« Reply #16 on: June 12, 2018, 06:27:54 am »
When I hit Save, here's what a log looks like.
One thing, it would be nice to have a "pause" button on the screen to stop the graph scrolling while you look at it.
Even better if it keeps collecting data in the background like a "lap" button on a stopwatch, so that when you unfreeze it refreshes the graph with the extra data collected.
Another thing, it would be nice if the collection interval was a round number of seconds per sample.
(Also, I'm not sure that many digits of time resolution are meaningful.)
Time (s), Voltage DC (V)
0.05082, 0.0005
0.111293, 0.0006
0.831361, 0.0006
1.310702, 0.0006
1.820419, 0.0006
2.331409, 0.0006
2.811417, 0.0006
3.321496, 0.0006
3.831209, 0.0006
4.311489, 0.0006
4.821054, 0.0006
5.331481, 0.0006
5.811364, 0.0006
6.354458, 0.0006
6.831573, 0.0006
7.341693, 0.0006
7.851459, 0.0006
8.362003, 0.0006
8.84111, 0.0006
9.351552, 0.0006
9.831087, 0.0006
10.34146, 0.0006
10.85149, 0.0006
11.33111, 0.0006
11.84133, 0.0006
12.35151, 0.0006
12.83109, 0.0006
13.34188, 0.0006
13.85141, 0.0005
14.33115, 0.0005
14.84186, 0.0006
15.35119, 0.0006
15.83165, 0.0006
16.34118, 0.0006
16.85153, 0.0006
17.33162, 0.0006
17.84163, 0.0006
18.32146, 0.5945
18.83173, 1.1663
19.34166, 1.1667
19.82151, 1.1668
20.33185, 1.1669
20.84128, 1.1669
21.32154, 1.167
21.83112, 1.1669
22.3415, 1.1669
23.39187, 1.7364
23.84181, 1.9943
24.35119, 2.2268
24.86161, 2.472
25.37127, 2.5748
26.36175, 2.8239
26.87211, 3.186
27.8619, 3.4225
28.37129, 3.616
28.85251, 3.7305
29.36153, 3.7714
29.8413, 3.7646
30.35259, 3.6201
30.86128, 3.2969
31.34081, 3.2651
31.85176, 3.0388
32.36143, 2.8243
32.84133, 2.681
33.35179, 2.4726
33.86126, 2.3725
34.34166, 1.959
34.85123, 1.7717
35.36166, 1.671
35.84135, 1.538
36.35189, 1.3377
36.86134, 1.193
37.34202, 1.023
37.85187, 0.8286
38.36124, 0.6537
38.84189, 0.4542
39.35125, 0.3038
40.37312, 0.3377
40.88191, 0.8073
41.39137, 0.9643
41.87184, 1.1038
42.38153, 1.2069
42.89182, 1.306
43.37132, 1.3699
43.88216, 1.4626
44.39149, 1.835
44.87186, 1.9696
45.38192, 2.0328
45.86183, 2.3166
46.3714, 2.5065
46.8819, 2.6848
47.36154, 2.7752
47.87173, 2.8638
48.38136, 3.2833
48.86201, 3.3274
49.3713, 3.0582
49.88185, 2.7308
50.36157, 2.4973
50.87258, 2.474
51.38154, 2.4739
51.86174, 2.4988
52.37157, 2.6343
52.88213, 2.7196
53.36198, 2.8503
53.87187, 2.9742
54.38151, 3.1615
54.86172, 2.9191
55.37134, 2.7235
55.882, 2.5513
56.39146, 2.3564
56.87197, 2.1195
57.38156, 1.9043
58.40196, 1.4635
58.88206, 1.2855
59.39145, 1.2619
59.90191, 1.0454
60.41146, 0.9032
61.40224, 1.1442
61.91229, 1.2656
62.39143, 1.2689
« Last Edit: June 12, 2018, 06:33:47 am by IanB »
Offline mtdoc
Re: 121GW App Testing
« Reply #17 on: June 12, 2018, 06:46:18 am »
Ok just checked on my iPhone 5s. Logging “save” button works fine there. But still no joy on the iPad mini.
Offline Seppy
  • Curious
« Reply #18 on: June 12, 2018, 06:51:48 am »
Could you take a screenshot of these two issues, do you
Doh, OK  of course.
Can you take a screenshot that shows your full portrait screen with one of the DC values that do not correspond, will help in isolating any issue.
I'll try get my hands on an iPad Mini, I haven't got one to test with so in the mean time what are settings that resulted in that error, does it happen every time?
Offline plexus
« Reply #19 on: June 12, 2018, 07:18:27 am »
I just got a notification about a post in the discussion forum and ended up here. I am an iOS user. iphone 6, ipad mini, iphone 4. Looking forward to an iOS app!
Offline mtdoc
« Reply #20 on: June 12, 2018, 07:20:59 am »
Doh, OK  of course.
Will do tomorrow. Late here now. Meter put away and me too. Thanks for your work on this.
Offline Seppy
  • Curious
« Reply #21 on: June 12, 2018, 08:08:39 am »
You can use the app now if you like, just fill in the form at the top of the page and become a beta tester :)
Offline Kean
    • Kean Electronics
« Reply #22 on: June 12, 2018, 08:41:50 am »
Will run some tests with my iPhone 6 tomorrow once I put my meter back together (again).
My iPad mini is the original model, so it can't run iOS 11 unfortunately.  I considered upgrading, but I just don't use it enough (or do enough iOS app dev) to justify buying a new model.  I may have to eventually now that Apple is forcing all new apps to be built for iOS 11.
Offline djadeski
« Reply #23 on: June 12, 2018, 05:21:34 pm »
Just got the app loaded and here are a number of screenshots from running temperature monitoring and setting up and running the maths function on the temperature using the one device for both inputs, showing selecting the settings and the outcome.  From an iphone 7 iOS 11.4.  If there are specific use cases you want captured let me know.
I accumulated the screen shots in dropbox which can be found here: https://www.dropbox.com/sh/h55xuwofz8025z9/AADyFKSlYDJ_HJe0xtVhYkqNa?dl=0.
Everything seemed to be working with the exception of the vertical units which are not degrees.
-dave
Offline IanB
« Reply #24 on: June 12, 2018, 08:30:06 pm »
I just read the App Store submission guidelines, and while it says apps must be able to run on the currently shipping OS it doesn't say they can't run on older versions of the OS.
It would be very helpful for people with older devices or people who don't want to be on the bleeding edge of OS releases if the app could run on iOS 10 or earlier.
Are there any specific features of iOS 11 that it relies on? This is the first App I have tried that insists on iOS 11.3 as the minimum supported version.
