Author Topic: 121GW App Testing  (Read 35297 times)
Offline SeppyTopic starter
  • Curious
Re: 121GW App Testing
« Reply #150 on: August 14, 2018, 06:23:28 am »
The first actual need I had to log data on the 121GW revealed a bug in the iOS app.
Meter FW: 1.22
iOS App: Build 1.6
AC Current reading is off on the iOS device by either 100x high or 10x low.
121GW         App            Range
1.0007 mA    100.07 mA    Auto
1.0007 mA    100.07 mA    First manual
1.002  mA    0.1002 mA    Second manual
Alright, do you know if that is a permanent issue or just the first time it samples?
This can be resolved quite quickly, depending.
Offline JonM
« Reply #151 on: August 14, 2018, 07:01:06 am »
It happens all the time. It seems like there is some conversion issue that is wrong only for AC current. I could not find a problem with any other mode.
  • Curious
« Reply #152 on: August 23, 2018, 03:33:34 am »
Found the issue, it will be released after I can get my hands on the test devices.
If you curious, there was a rouge 3 in the source. ???
Offline Brumby
« Reply #153 on: August 23, 2018, 10:59:29 am »
Is that colour-sensitive programming - or a misspelled "rogue"?
(sorry)
« Last Edit: August 23, 2018, 11:02:31 am by Brumby »
The following users thanked this post: Kean
  • Curious
« Reply #154 on: August 24, 2018, 12:28:15 am »
(sorry)
misspelt rogue  :palm:.
Offline dcac
« Reply #155 on: August 25, 2018, 09:48:14 pm »
I can't get the Windows app working that's available here: https://www.microsoft.com/en-au/store/p/eevblog-121gw/9n2681hjrtm8
The 121gw BT pairing seems to be working and "121GW BluetoothLE#......" is displayed in the app - clicking this shows "Connecting..." for a few seconds - but then nothing - just a blank screen.
I'm using windows 10 v1803 and a HP Zbook g2 laptop.
Online IanB
« Reply #156 on: August 27, 2018, 07:38:34 am »
On the Windows 10 app, I recorded a lot of data and then saved to a csv file, which was created OK. However, when I later went back to look at the log file I found it to have zero size and was empty. On a second attempt following the same steps with the same amount of data (about 10 minutes worth), the file was created successfully. So I don't know how to reproduce the problem.
(BTW, maybe this thread could be pinned like the other 121GW threads? I had to scroll down quite a bit to find it.)
Offline JS
  • Country: ar
« Reply #157 on: August 27, 2018, 08:12:31 am »
Hi, I haven't been able to log the second display, not with the APP or to the SD card (forgot to check in VA mode which really should work)
Is there anything about this or is something that might be added in the future?
Thanks!
JS
If I don't know how it works, I prefer not to turn it on.
Offline dcac
« Reply #158 on: August 27, 2018, 11:48:04 am »
I second that, the App and BT functionality is an important part of the 121gw package, perhaps this thread should be pinned trying to keep these specific issues out of the other 121gw threads.
Online IanB
« Reply #159 on: August 28, 2018, 02:20:31 am »
OK, I just reproduced it a second time. I was running the app on Windows 10 and recorded several minutes of data (10 minutes or so). Then I tried to save it to a csv file. On the first attempt it produced a file with zero bytes. However, a second attempt succeeded.
Online IanB
« Reply #160 on: August 28, 2018, 02:27:35 am »
The Bluetooth interface on Windows 10 seems very touchy. I got the meter to pair, but it wouldn't connect for more than a second or two before going back to paired. When the app was launched then most of the time the meter did not show up. When it did show up a connect attempt produced a "Connecting..." message from the app that lasted forever.
In the end I got it to work by rebooting the computer.
This might be a Windows 10 problem. Maybe it is outside your control. Many Bluetooth devices fail to work properly under Windows 10 as a quick Google search will verify.
(I have not seen any connection issues with iOS.)
Offline dcac
« Reply #161 on: August 28, 2018, 01:09:39 pm »
Yeah very touchy indeed, my Zbook G2 is supposed to be BT 4.0 + LE compliant but as it seems not compliant enough. Disabling the BT in bios and using a cheap BT 4.0 dongle instead the Win 10 App works. Haven't tested it much more though, mainly wanted to check that wasn't a problem with the meter.
  • Curious
« Reply #162 on: September 04, 2018, 05:38:12 am »
It is at least somewhat windows related, some drivers behave very differently.
You shouldn't actually need to pair at all. Might take a while to appear though...
If you didn't pair before try do that (even though it shouldn't be necessary, some drivers treat this slightly differently).
There is a new version of the windows up released, major changes.
There was a dependency that I was waiting for that wouldn't allow an update to be released until it itself was updated.
  • Curious
« Reply #163 on: September 04, 2018, 05:41:27 am »
Looking into this, i the mean time are you able to try the latest update?
It is still processing and might take a day to appear everywhere in the store.
« Last Edit: September 04, 2018, 05:43:36 am by Seppy »
Online IanB
« Reply #164 on: September 04, 2018, 05:56:31 am »
I will see if I can try the latest update some time in the next few days.
  • Curious
« Reply #165 on: September 04, 2018, 06:26:41 am »
Awesome, I've been testing the file save issue for every 10 minutes for over an hour. No failures, has there been any common factors in the issue?
Online IanB
« Reply #166 on: September 04, 2018, 06:45:19 am »
I can't think of anything special except I may have cleared the history once or twice before collecting the data I wanted to save. Everything looked right about the save operation except the file on disk was empty afterwards.
  • Curious
« Reply #167 on: September 04, 2018, 06:52:04 am »
Did it take a second to save, app freeze for about a second?
Online IanB
« Reply #168 on: September 04, 2018, 07:04:45 am »
I don't recall, I'd have to try again.
  • Curious
« Reply #169 on: September 05, 2018, 02:25:52 am »
Update for the windows app will now be automatically installed on client machines.
Offline JonM
« Reply #170 on: September 05, 2018, 03:40:24 am »
How is that iOS update coming? The current version expires in 15 days. I will be traveling in 10 days and may have to take an AC current source with me for testing unless I can test the new version (with the '3' removed) before then.
I will carry the 121GW with me in any case...
Thanks!
  • Curious
« Reply #171 on: September 05, 2018, 03:50:21 am »
Thanks!
iOS version is on the app store :)
Offline JonM
« Reply #172 on: September 06, 2018, 01:21:07 am »
Thanks!
OK, I got iOS App v1.7 from the app store and still saw the AC mA problem with firmware 1.22.
Now I have upgraded to firmware 1.26 and I am still seeing the problem.
1.0011 mA on meter reads 100.11 on iOS app
  or
0.983 on meter reads 0.0983 on iOS app
depending on range.
DCA does not have the problem
Do you need further diagnostics on this?
Thanks.
Online IanB
« Reply #173 on: September 06, 2018, 03:12:51 am »
Yes, it happens on the Windows app too. Meter shows "AUTO AC 0.0798 mA", app shows "AUTO AC 7.98 mA".
Online IanB
« Reply #174 on: September 06, 2018, 03:24:58 am »
Now the Windows app spontaneously fixed itself, but the iOS app still shows the wrong decimal place.
