Author Topic: Read 121GW SD card by bluetooth  (Read 504 times)
Offline jms019Topic starter
« on: January 22, 2024, 10:31:13 am »
Is it possible to log to SD card then later fetch the data over bluetooth ?
I cannot find the answer anywhere.
Jon
Offline Kean
    • Kean Electronics
Re: Read 121GW SD card by bluetooth
« Reply #1 on: January 22, 2024, 11:09:06 am »
No, this was never implemented in the 121GW firmware.  It has been discussed before, but not sure it is actually "documented".
Here are a couple of links mentioning it that I found with a quick search.
https://www.eevblog.com/forum/testgear/eevblog-121gw-discussion-thread/msg2690580/#msg2690580
https://www.eevblog.com/forum/testgear/eevblog-121gw-discussion-thread/msg4724672/#msg4724672
The following users thanked this post: jms019
