Author Topic: Ready-to-use DMM analog front end module?  (Read 370 times)
Offline jezel123Topic starter
« on: March 14, 2024, 10:05:01 am »
Hi everyone
I am planning to make a 5 digit bench DMM which uses Nixies for the display. Now, I don't have a lot of experiece when it comes to analog PCB design, and I would like to avoid wasting a lot of time and money on prototypes for the analog front end, so I thought, surely there have to exist some sort of ready-to-use precision DMM modules with simple serial communication, but I cant find any. It is entirely possible that I just don't know the terminology and am searching for the wrong thing.
Best thing I found is a Cyrustek ES51997 IC, but I haven't found any reference design for it.
Things I want to measure:
  • Voltage (AC and DC) between 100uV and 240V
  • Current (AC and DC) between 100uA to 2A
  • Resistance between 1 Ohm and 10MOhm
  • Capacitance between few nF up to few mF
  • Diode Test
  • Frequencies between a few Hz up to 16 MHz (doesn't have to be precise)
Thanks in advance!
Offline iMo
  • Country: pm
  • It's important to try new things..
Re: Ready-to-use DMM analog front end module?
« Reply #1 on: March 14, 2024, 10:13:10 am »
Hi everyone
I am planning to make a 5 digit bench DMM which uses Nixies for the display. Now, I don't have a lot of experiece when it comes to analog PCB design, and I would like to avoid wasting a lot of time and money on prototypes for the analog front end..
Ready to use analog FE could be get from ADI
https://www.eevblog.com/forum/metrology/adi-admx3652-6-digit-20-v-dvm/
It is just an +/-20V FE, all others has to be created by you. Mind 5-6 digits with your above reqs is a pretty difficult project, imho.
Offline Kleinstein
« Reply #2 on: March 14, 2024, 10:30:11 am »
The DMM chip sets are usually made for lower resolution, not really 5 digits. They are build for low power, not high performance. This starts with a relatively low voltage range without a divider.
The ES51997 seems to still use a dual slope ADC and would thus have a hard time to push it beyond is intended specs (60000 counts).
There may be a different front end chip that could maybe be pushed to the 5 digit (99999 counts) range.
I difficulty may be to get those more special chip in small quantety.
There was such a board available:
https://digilent.com/reference/add-ons/dmm-shield/reference-manual
« Reply #3 on: March 14, 2024, 10:54:20 am »
I know, that is why I find it surprising that there isn't any alternative to this.
