Definitely go for IPS if you can, DMM6500 uses a COTS display with early units being TN, later IPS, the later ones look much nicer.
Five-inch capacitive touch, color thin-film-transistor (TFT) WVGA (800×480) with LED backlight.
Quote from: wraper on January 27, 2025, 03:33:18 pmNot the same LCD model but most likely should work just fine as it uses pretty standard LCD, worth a try for just $9. https://www.aliexpress.com/item/1005005199455421.htmlI can confirm that IPS LCD from Aliexpress works fine in 34461A. Since it costs peanuts, I thought it wasn't a bad idea to upgrade TN display in my early 34461A. Good brightness, viewing angles, contrast.
