Correct. You entered into a contract to purchase one FSM+, the manufacturer gave you that FSM+, that is what you "were handed", that is what "you own". Contract satiisfied.
This is not quite correct.
Yes, you entered into an implied contract to exchange a certain amount of money for a device with certain specific characteristics. What you were handed was a device that, as configured, has those specific characteristics. The implied contract covers the exchange only. It does not cover anything beyond that.
But as regards the scopes we're talking about,
what you were actually handed has the built-in potential to be more than what the manufacturer specified. Since you own what you actually were handed, including all of the built-in potential for greater capability (whether or not you are capable of configuring the device so that it reaches its potential is a different question), it follows that what you own, in fact, has the potential to be better than what the manufacturer stated. This represents a possibly greater value than what you can rightly expect based on the implied contract.
Note that what you receive does not necessarily include everything you need in order to get the device to reach its potential. And in the case we're talking about here, that is indeed the case: you're not given the codes necessary to configure the device to its maximum potential. But the potential itself is still there.
In this case, you have to take some additional steps in order to configure the device so that it can achieve its full potential. But because that additional potential exists within what you were handed, we're now talking about whether or not you have access to whatever is necessary (which can include hardware, software, skills, or whatever) in order to make the device realize its full potential.
Not a different FSM+ that you could have contracted to buy at a higher price - but chose not to because you didn't like the price.
What you received at the time is something that was configured to have the advertised characteristics, but nothing prevents the manufacturer from giving you something with greater potential than that. And in this case, the manufacturer handed you something with greater potential than what you implicitly contracted for.
The manufacturer is perfectly within its rights to give you something that
can't be reconfigured for greater capability (i.e. that has no greater potential than what it is capable of at the time of sale) but that still meets the original specifications. Whether the manufacturer chooses to do that or chooses to give you something with greater potential capability than what the implied contract specifies is up to the manufacturer.
Now, if you went into the transaction with the expectation that what you'd be getting is something with greater potential than what your implied contract specifies, then the error would be yours. So if, for instance, Rigol implements a hardware change in the DS1054Z that causes the front end to be limited to 50 MHz, with the end result being that an attempt to use a magic code to bring the unit to 100 MHz fails, then there is no foul there -- you're still getting a 50 MHz scope, just as the implied contract specifies, and thus you'd have no cause to complain even if your original desire was to configure it for 100 MHz operation.
But if what you receive does, in fact, have greater potential than what the implied contract states you're getting, then you are entirely within your rights to attempt to reconfigure the device to reach that potential. Nothing says that you have a right to
succeed in that attempt, obviously, but you are entirely within your rights to try (this assumes, of course, that the attempt isn't forbidden by the laws you operate under).
What of the above do you disagree with, and on what basis?
