Specs wise, the AP System One is reasonably high end when compared to sound cards, but certainly not the highest available nor even the highest price point, but there are reasons to consider it. It's going to be tested to have much more even response, it has a wider frequency response than many low noise sound cards, it has vastly superior input protection, and the integrated software is both good and free - comparable software will cost you something on the PC side, at least.
That said, it's bigger, could have worse overall noise/THD specs, the software and interface require older computer hardware to connect to it, and if I remember right, because of the sample rates it uses, there isn't a really easy lossless audio recording output from the software that's immediately playable in regular players.
I think the moral of my story is: if you don't mind the clunkiness associated with the older software/interface and have the bench space, the unit should be sufficient for the vast majority of analog audio work you're likely to do and should have a long lifetime. If space, power consumption, software portability, or the lowest THD/noise specifications are a concern, then maybe a higher end external sound card would be a better choice. A couple hundred on a good sound card and a software suite license can be very powerful tools if you don't need the stability guaranteed by calibrated test equipment - which is extra true when buying used without the intention to pay for a cal.
