Author Topic: Recomendations for a PWM Source  (Read 1620 times)
Offline mendip_discoveryTopic starter
« on: August 11, 2023, 05:10:42 pm »
I am looking for a portable bit of test gear that is sensibly priced and has a PWM (Power Wave Modulation) output.
I have a random eBay item that does it but it's an open circuit board and I could do with something that the customer won't start asking questions of. But at the same time I doubt I could get a Fluke Loop calibrator past the boss.
Motorcyclist, Nerd, and I work in a Calibration Lab :-)
So everyone is clear, Calibration = Taking Measurement against a known source, Verification = Checking Calibration against Specification, Adjustment = Adjusting the unit to be within specifications.
Re: Recomendations for a PWM Source
« Reply #1 on: August 11, 2023, 09:21:33 pm »
Not Pulse Width Modulation ?  :-//
What's the difference if you don't mind ?
Offline Fungus
« Reply #2 on: August 12, 2023, 06:16:05 am »
I don't think that's what PWM stands for.
Put it in a box?
Offline DavidAlfa
« Reply #3 on: August 12, 2023, 06:27:06 am »
Better detail yorurequirements a bit more. Plain PWM? Closed loop? Modulation input?...
This could get as basic as a 555 with a battery, to lots of  $$.
Offline Fungus
« Reply #4 on: August 12, 2023, 06:53:59 am »
Output frequency, precision, voltage, current...?
Or an Arduino.
« Reply #5 on: August 12, 2023, 07:40:49 am »
You are right, pulse width modulation. Not sure where I got power wave modulation from.
I have to test a machine that uses PWM as part of its tests. It generates and measures so I am looking for a neat way to do this. It 100 Hz at 50% so nothing special. The customer has a Fluke Loop calibrator but that is >£1000 which just for me to use on 4 machines is a little pricey. We are looking to get a handheld multimeter to do the measurement side of it, Fluke 87 or 287 depending on what we can find, that will at least have a use generally around the lab.
Offline DavidAlfa
« Reply #6 on: August 12, 2023, 08:13:24 am »
So the approach would be to manually verify the machine operation when setting different duty cycles, right?
These would do it for 5 bucks:
https://www.aliexpress.com/item/1005002771032403.html
https://www.aliexpress.com/item/1005004255904120.html
https://www.aliexpress.com/item/1005003352241302.html
« Last Edit: August 12, 2023, 08:22:24 am by DavidAlfa »
Online jpanhalt
« Reply #7 on: August 12, 2023, 10:02:40 am »
If all you need is 50% at 100 Hz, Paisley's compilation of circuits shows a simple way to get that with a 555: http://www.circuitous.ca/LM555.html#23
Since the 50% duty cycle is obtained by logic, my understanding is that it is relatively accurate; whereas, the frequency  that is dependent on an RC circuit is not so accurate.
Online Aldo22
« Reply #8 on: August 12, 2023, 11:28:08 am »
It's not entirely clear to me what you need.
If you just want to generate a square wave at 100Hz, maybe your cheap multimeter will do?
An8008 for example can do that quite accurately.
Online RAPo
« Reply #9 on: August 12, 2023, 12:22:41 pm »
Build your own and put it in a box.
Or if you want something fancier, would a fnirsi DSO-TC3 satisfy?
Very portable, and has a signal generator scope and component tester
« Reply #10 on: August 12, 2023, 12:52:09 pm »
I think the DSO-TC3 should do it fine. It's one of them jobs that if I turn up with something home made that I know I will get questions over it. It's a job I have ended up taking on becuase a bunch of cowboys decided they didn't want the job anymore, supposedly they also make multimeters but have to rebrand every few decades. As our firm is local to the job and my boss loves money I get volunteered to do the work, but as cheaply as possible.
The following users thanked this post: RAPo
Offline ledtester
« Reply #11 on: August 12, 2023, 06:07:16 pm »
There's also these signal generators... search aliexpress.com for "SG-003A Signal Generator".
https://a.aliexpress.com/_mO0Ng5s
