Author Topic: Recommend alligator clips & mini hook probes for BM789  (Read 1705 times)
Offline bird333Topic starter
« on: January 31, 2023, 11:43:15 pm »
Hey everyone.  I'm looking for recommendations for some alligator clips and mini hooks for my Brymen BM789.  Links would be much appreciated.  Thanks!
Offline mwb1100
Re: Recommend alligator clips & mini hook probes for BM789
« Reply #1 on: February 01, 2023, 01:09:25 am »
I've been happy with several "Sumnacon" silicone leads from Amazon.   Here's a set of alligator clip leads and a set of mini hook leads for $9:
  - https://www.amazon.com/Sumnacon-Multimeter-Test-Lead-Set/dp/B07F8R3VG9
However I personally prefer this style of alligator clip:
  - https://www.amazon.com/Sumnacon-Multimeter-Crocodile-Alligator-Stackable/dp/B073ZVJDCF
But then you're pushing the cost into the double digits  :)
Offline mwb1100
« Reply #4 on: February 01, 2023, 06:28:05 pm »
I have also bought leads and adapters from the 99centHobbies eBay store
It used to be run by an eevblog contributor (Franky - userid iloveelectronics).  The store was inactive after he turned it over to a relative and COVID hit, but it's running again (at least for shipping to USA).
Offline Martin72
  • Testfield Technician
« Reply #5 on: February 01, 2023, 10:16:24 pm »
This will be the next thing I will buy, after I already have the test leads from them:
https://www.welectron.com/Probe-Master-8043SK-Softie-Test-Lead-Master-Kit_1
Superb quality made in USA.
The following users thanked this post: dreamcat4
Offline eetechTom
« Reply #6 on: February 03, 2023, 08:25:12 pm »
Seems they have a foreplay related application as well. Read the second paragraph in the prescription ::) OUCH!
The following users thanked this post: mwb1100
Offline mwb1100
« Reply #7 on: February 04, 2023, 01:16:03 am »
I didn't mention why I preferred them!    :D
Offline Gyro
« Reply #8 on: February 04, 2023, 10:44:08 am »
The KAIWEETS KET01 lead set is surprisingly good for the money. They give you the option of probes, small croc clips and thinner wire mini-grabbers. The probes seem to make decent contact and total lead resistance is around 100mR. They are available separately on Amazon.co.uk but so far, I've only found them bundled with other stuff on Amazon.com...  https://www.amazon.co.uk/Multimeter-KAIWEETS%C2%AE-Alligator-Mini-Hooks-Voltmeter/dp/B07SD3L9HR/
Best Regards, Chris
Offline mwb1100
« Reply #9 on: February 04, 2023, 04:28:21 pm »
Available on Amazon US for $16 here: https://www.amazon.com/KAIWEETS-Electrician-Alligator-Multimeter-Electronic/dp/B07SD3L9HR
