You mean the error with the power splitter?
BTW I looked at other assemblies from HP/Agilent/Keysight that perform the same function as a reflection/transmission analyzer add-on and the circuit diagram looks like a power splitter that is connected to the R port through a black box (not sure if this is a resistor/attenuator or a isolator and then to a directional coupler.
I think the directional coupler only isolates the coupled port (3), and between 1 and 2 you just have a attenuator (10dB in the case of the coupler), so you have a 6db loss on the power splitter, then a 10dB loss from the directional coupler (which is not directional in attenuation for a signal you pass)
I thought it would be designed like a dual directional coupler.
How come they go to use a directional coupler, resistive splitter and some kind of series thing (either resistor/attenuator or isolator, drawn as a black rectangle) rather then a dual directional coupler?
Is it just because the thing goes down to low frequencies where you can't use a directional coupler to feed the R port? (the HP recommended part is DC to GHz).. I would assume a microwave VNA just uses a dual directional coupler rather then the weird hybrid of splitter and coupler?
What are practical low frequency limits for a directional coupler? Do they have ones that use the stripline coupler and a transformer to handle wide bands?>
