Author Topic: recommendation on scope, is there a recent list on gear ?  (Read 1366 times)
Offline Oy1rTopic starter
  • Country: fo
My fluke pm3380 gave up the ghost, anode high voltage failed, i tried to get a new board but the result was not very good. So i'm looking for a new one.
What is the latest EEVblog recommendation on entry/hobby scopes ?
Preferably something i can get in Europe.
oy1r
Re: recommendation on scope, is there a recent list on gear ?
« Reply #1 on: July 20, 2021, 12:11:41 am »
Very dependent on needs and budget.
BW ?
2 or 4 channels ?
MSO ?
Additional features required ?
Traditional UI or with touch display ?
And so on......
Avid Rabid Hobbyist
Online Fungus
« Reply #2 on: July 20, 2021, 07:17:25 am »
Budget?
Number of channels?
These forums are literally overflowing with this discussion. Try reading a few threads.
« Last Edit: July 20, 2021, 08:19:29 am by Fungus »
The following users thanked this post: egonotto, oz2cpu
  • Country: fo
« Reply #3 on: July 20, 2021, 10:39:40 am »
3 channels should be enough  i guess. i remember the Rigol 1052 or 54 being mentioned on eev youtube, i was thinking maybe something newer but similar. i could spend around 5 to 800 us$ on a new toy !
Reg
« Reply #4 on: July 20, 2021, 10:47:52 am »
Reg
SDS1104X-E for $499 is well thought of here and the bit cheaper $399 SDS1104X-U might fit your needs too.
Happy hunting.
Rob
Avid Rabid Hobbyist
Online tggzzz
« Reply #5 on: July 20, 2021, 11:02:27 am »
There are many tedious repetitive threads here. Feel free to browse them.
You should always start by defining what you will and won't use it for.
Next understand the class of probe you need to use, and budget for that.
Finally, leave money for all the other things you will need.
« Last Edit: July 20, 2021, 12:40:49 pm by tggzzz »
Offline tv84
  • Country: pt
« Reply #6 on: July 20, 2021, 11:32:55 am »
This one is really fresh! Do your part.
  • Country: fo
« Reply #7 on: July 20, 2021, 07:44:04 pm »
Thanks i appreciate the input. having had a scope and then loosing it is a pita. even though one is just an amateur electronics  geek!  :-BROKE
  • Country: fo
« Reply #8 on: July 23, 2021, 01:47:03 am »
I started with a 2ch 100MHz scope. So that was the bare minimum i wanted, i ended up ordering the Siglent SDS1202X-E and and probes.
Looking forward to getting it.
Reg
  • Country: fo
« Reply #9 on: July 23, 2021, 01:59:09 am »
Oh and while i was at it. i ordered an arbitrary wave generator 2ch 30MHz.!
« Reply #10 on: July 23, 2021, 02:00:16 am »
Both popular models for us in NZ and they will serve you well.
Congrats and enjoy.  :)
Avid Rabid Hobbyist
  • Country: fo
« Reply #11 on: July 23, 2021, 06:43:16 pm »
Encouraging thanks.
The choice is huge, i didnt konw what exactly to get, so after a few hours i just decided on these two, i could sit a few more hours and still not make a choice !
The signal gen is Siglent SDG1032X.
a second multimeter could be handy. perhaps a bench model.
73
Reg, OY1R
